By onurbilke
#83986 Hi everybody. When I connected ESP GPIO0 -> 1K -> BC237 (NPN) transistor Base -> Relay I can't control the relay. But I connected ESP GPIO0 -> LED (Serial "+ Connected GPIO 0 and - Connected Transistor") -> BC237 (NPN) transistor Base -> Relay it is working very good. I can't understand this problem. I tried pull down GPIO0 with 10K resistor but the result same. I am writing code with arduino ide. I set GPIO0 as output. Thank you.
By QuickFix
#84004 This is a forum about electronics and programming, not crystal ball readers unlimited: please show us some code and an actual schematic. :idea:
