By penright
#85209
icons wrote:It also looks like one of your capacitors is fallen off on the S one.
Little off-topic, what capacitor? Where? It does not have a good WiFi signal. I was using it as a Tuya Convert Donor. The Tuya Convert, using a PI WiFi in AP mode, needs a device connected to it besides the device you are trying to flash (Tasmota). It works for sitting next to the PI, but it will not connect to the building AP. Not sure if any of that makes sense, just wondering if the "missing capacitor" could be the reason.
By icons
#85217 I just tried with 1.8.5 & 2.4.2 on a different computer and it works, though had to reboot computer also I hope you realize that with that esp8266 flasher you need to unplug it after every upload even if it fails, then plug back in. Also on my desktop it only works with USB which is on the motherboard, on the back of computer not the USB that is connected to chassis. Its kind of temperamental. Have you tried a different ESP8266 maybe that one is no good?
P.S. sorry for the huge photo.
By penright
#85219 I will study the pictures. I need to get my old man "magnify glass" out. I have to wait till night so I will not accidentally start a fire.
First, no I was not un-plug/plug between tests. My bad.
I did move it to the back, rebooted, still did not load. I guess you did not see any issue with my Tool settings, did you?
Log from the try on the back USB. You can see the comport changed. There has to be something stupid I am missing.
Code: Select all"C:\Users\paulenright\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\PAULEN~1\AppData\Local\Temp\arduino_build_734727/arduino.ar" "C:\Users\PAULEN~1\AppData\Local\Temp\arduino_build_734727\core\spiffs_hal.cpp.o"
Archiving built core (caching) in: C:\Users\PAULEN~1\AppData\Local\Temp\arduino_cache_808575\core\core_esp8266_esp8266_generic_CpuFrequency_80,VTable_flash,ResetMethod_ck,CrystalFreq_26,FlashFreq_40,FlashMode_dout,FlashSize_1M0,led_2,LwIPVariant_v2mss536,Debug_Disabled,DebugLevel_None____,FlashErase_none,UploadSpeed_115200_d6701caec6cd565e8e057befb3154f0b.a
Linking everything together...
"C:\Users\paulenright\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-gcc" -CC -E -P -DVTABLES_IN_FLASH "C:\Users\paulenright\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2/tools/sdk/ld/eagle.app.v6.common.ld.h" -o "C:\Users\paulenright\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2/tools/sdk/ld/eagle.app.v6.common.ld"
"C:\Users\paulenright\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-gcc" -Wl,-Map "-Wl,C:\Users\PAULEN~1\AppData\Local\Temp\arduino_build_734727/Tuya-Convert-Donor.ino.map" -g -w -Os -nostdlib -Wl,--no-check-sections -u app_entry -u _printf_float -u _scanf_float -Wl,-static "-LC:\Users\paulenright\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2/tools/sdk/lib" "-LC:\Users\paulenright\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2/tools/sdk/ld" "-LC:\Users\paulenright\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2/tools/sdk/libc/xtensa-lx106-elf/lib" "-Teagle.flash.1m0.ld" -Wl,--gc-sections -Wl,-wrap,system_restart_local -Wl,-wrap,spi_flash_read  -o "C:\Users\PAULEN~1\AppData\Local\Temp\arduino_build_734727/Tuya-Convert-Donor.ino.elf" -Wl,--start-group "C:\Users\PAULEN~1\AppData\Local\Temp\arduino_build_734727\sketch\Tuya-Convert-Donor.ino.cpp.o" "C:\Users\PAULEN~1\AppData\Local\Temp\arduino_build_734727\libraries\ESP8266WiFi\BearSSLHelpers.cpp.o" "C:\Users\PAULEN~1\AppData\Local\Temp\arduino_build_734727\libraries\ESP8266WiFi\CertStoreBearSSL.cpp.o" "C:\Users\PAULEN~1\AppData\Local\Temp\arduino_build_734727\libraries\ESP8266WiFi\ESP8266WiFi.cpp.o" "C:\Users\PAULEN~1\AppData\Local\Temp\arduino_build_734727\libraries\ESP8266WiFi\ESP8266WiFiAP.cpp.o" "C:\Users\PAULEN~1\AppData\Local\Temp\arduino_build_734727\libraries\ESP8266WiFi\ESP8266WiFiGeneric.cpp.o" "C:\Users\PAULEN~1\AppData\Local\Temp\arduino_build_734727\libraries\ESP8266WiFi\ESP8266WiFiMulti.cpp.o" "C:\Users\PAULEN~1\AppData\Local\Temp\arduino_build_734727\libraries\ESP8266WiFi\ESP8266WiFiSTA.cpp.o" "C:\Users\PAULEN~1\AppData\Local\Temp\arduino_build_734727\libraries\ESP8266WiFi\ESP8266WiFiScan.cpp.o" "C:\Users\PAULEN~1\AppData\Local\Temp\arduino_build_734727\libraries\ESP8266WiFi\WiFiClient.cpp.o" "C:\Users\PAULEN~1\AppData\Local\Temp\arduino_build_734727\libraries\ESP8266WiFi\WiFiClientSecureAxTLS.cpp.o" "C:\Users\PAULEN~1\AppData\Local\Temp\arduino_build_734727\libraries\ESP8266WiFi\WiFiClientSecureBearSSL.cpp.o" "C:\Users\PAULEN~1\AppData\Local\Temp\arduino_build_734727\libraries\ESP8266WiFi\WiFiServer.cpp.o" "C:\Users\PAULEN~1\AppData\Local\Temp\arduino_build_734727\libraries\ESP8266WiFi\WiFiServerSecureAxTLS.cpp.o" "C:\Users\PAULEN~1\AppData\Local\Temp\arduino_build_734727\libraries\ESP8266WiFi\WiFiServerSecureBearSSL.cpp.o" "C:\Users\PAULEN~1\AppData\Local\Temp\arduino_build_734727\libraries\ESP8266WiFi\WiFiUdp.cpp.o" "C:\Users\PAULEN~1\AppData\Local\Temp\arduino_build_734727/arduino.ar" -lhal -lphy -lpp -lnet80211 -llwip2 -lwpa -lcrypto -lmain -lwps -lbearssl -laxtls -lespnow -lsmartconfig -lairkiss -lwpa2 -lstdc++ -lm -lc -lgcc -Wl,--end-group  "-LC:\Users\PAULEN~1\AppData\Local\Temp\arduino_build_734727"
"C:\Users\paulenright\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.13/esptool.exe" -eo "C:\Users\paulenright\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2/bootloaders/eboot/eboot.elf" -bo "C:\Users\PAULEN~1\AppData\Local\Temp\arduino_build_734727/Tuya-Convert-Donor.ino.bin" -bm dout -bf 40 -bz 1M -bs .text -bp 4096 -ec -eo "C:\Users\PAULEN~1\AppData\Local\Temp\arduino_build_734727/Tuya-Convert-Donor.ino.elf" -bs .irom0.text -bs .text -bs .data -bs .rodata -bc -ec
Using library ESP8266WiFi at version 1.0 in folder: C:\Users\paulenright\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\ESP8266WiFi
Sketch uses 253900 bytes (24%) of program storage space. Maximum is 1023984 bytes.
Global variables use 28544 bytes (34%) of dynamic memory, leaving 53376 bytes for local variables. Maximum is 81920 bytes.
C:\Users\paulenright\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.13/esptool.exe -vv -cd ck -cb 115200 -cp COM37 -ca 0x00000 -cf C:\Users\PAULEN~1\AppData\Local\Temp\arduino_build_734727/Tuya-Convert-Donor.ino.bin
esptool v0.4.13 - (c) 2014 Ch. Klippel <ck@atelier-klippel.de>
   setting board to ck
   setting baudrate from 115200 to 115200
   setting port from COM1 to COM37
   setting address from 0x00000000 to 0x00000000
   espcomm_upload_file
   espcomm_upload_mem
   setting serial port timeouts to 1000 ms
opening bootloader
resetting board
trying to connect
   flush start
   setting serial port timeouts to 1 ms
   flush complete
   espcomm_send_command: sending command header
   espcomm_send_command: sending command payload
   read 0, requested 1
trying to connect
   flush start
   flush complete
   read 0, requested 1
trying to connect
   flush start
   flush complete
   read 0, requested 1
resetting board
trying to connect
   flush start
   flush complete
   read 0, requested 1
trying to connect
   flush start
   flush complete
   read 0, requested 1
trying to connect
   flush start
   flush complete
   read 0, requested 1
resetting board
trying to connect
   flush start
   flush complete
   read 0, requested 1
trying to connect
   flush start
   flush complete
   read 0, requested 1
trying to connect
   flush start
   flush complete
   read 0, requested 1
warning: espcomm_sync failed
error: espcomm_open failed
error: espcomm_upload_mem failed
