By pjarki
#86888 Hi! I made this simple sketch to show some text on a DOT Matrix using a Wemos D1 mini. Everything works fine except that when I disconnect it from power and reconnect it, it seems to run the sketch like normal but nothing is displayed.
Any help would be appreciated. I am putting everything inside a small box that is screwed together so I can't reach the reset button from outside of the box...
Here's the code:
Code: Select all// Libraries included
#include <MD_Parola.h>
#include <MD_MAX72xx.h>
#include <SPI.h>
#include "Arduino.h"
#include <WiFiClientSecure.h>
#include "JsonStreamingParser.h"
#include <ArduinoJson.h>
#include "InstagramStats.h"
#include <YoutubeApi.h>
#include "theSwedishMaker.h"
const uint16_t WAIT_TIME = 6000; //Time between fecthing data.
// Define the typ of hardware and the pins used.
#define HARDWARE_TYPE MD_MAX72XX::FC16_HW
#define MAX_DEVICES 4
#define CLK_PIN   12
#define DATA_PIN  15
#define CS_PIN    13
// Hardware SPI connection
//MD_Parola P = MD_Parola(HARDWARE_TYPE, CS_PIN, MAX_DEVICES);
// Arbitrary output pins
MD_Parola P = MD_Parola(HARDWARE_TYPE, DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES);
#define API_KEY "********" //Your Youtube API-Key
#define CHANNEL_ID "Youtube Channel ID" // Your youtube channel ID.
String userName = "TheSwedishMaker"; // Your Instagram Username
WiFiClientSecure client; //For ESP8266 boards
InstagramStats instaStats(client);
YoutubeApi api(API_KEY, client);
// Configuration of router settings
const char* ssid     = "NETWORKNAME";      // SSID of local network
const char* password = "*******";                // Password on network
void setup()
  P.begin();
  P.setFont(fontSubs);
  // Connecting to wifi
  Serial.print("Connecting WiFi ");
  WiFi.begin(ssid, password);
  P.print(" WiFi...");
    Serial.print("."); delay(500);
  Serial.println("");
  Serial.print("Connected: "); Serial.println(WiFi.localIP());
  client.setInsecure();
void loop(void)
  Serial.println("Getting data ...");
  P.print("fetching");
  int cnt = 0;
  //int yt1;
  long yt1,yt2,insta;
    while(1) {
    if(!cnt--) {
     cnt = 50;
     if(api.getChannelStatistics(CHANNEL_ID))
      yt1 = api.channelStats.subscriberCount;
      yt2 = api.channelStats.viewCount;
      InstagramUserStats response = instaStats.getUserStats(userName);
      insta = response.followedByCount;
    // FORMATO
       String subsCount = num_format(yt1);
       String viewCount = num_format(yt2);
       String instaFollowers = num_format(insta);
    // PRINT
    Serial.println(subsCount);
    P.print("*" + subsCount);
    delay(3500);
   // P.print("*" + viewCount); //Uncomment if your want to show viewcount.
   // delay(3500); //Uncomment if you want to show viewcount.
    P.print("&" + instaFollowers);
    delay(5000);
String num_format(long num){
     String num_s;
     long num_original = num;
     if (num>99999 && num<=999999){
        num = num / 1000;
        long fraction = num_original%1000;
        String num_fraction = String(fraction);
        String decimal = num_fraction.substring(0,1);
        num_s = String(num) + "." + decimal + "K";
    else if(num>999999){
        num = num / 1000000;
        long fraction = num_original%1000000;
        if (num_original<100000000){
          num_s = " " + String(num) + "." + decimal + "M";
        else{
        num_s = String(num) + "." + decimal + "M";
    else{
        int num_l = String(num).length();
        char num_f[15];
        int blankDigits = 6 - num_l;
        for(int i = 0; i < blankDigits; i++){
          num_f[i] = ' ';
        num_f[blankDigits] = '\0';
        num_s = num_f + String(num);
    return num_s;
