By Matt SegFault
#93538 Hi all,
I have a 16 channel relay controller (12v version) with an inbuilt wifi and 8266 processor, you've probably seen them around
https://www.aliexpress.com/item/1005003319135693.html
The board has 2 x 74HC595 units to control which relay(s) to turn on and off
I have managed to deduce that the pins defined in code below work and I can turn on a few of the relays.
What I don't understand is how the data needs to be formatted to send to the 74HC595 shift registers. For example I get different outcomes based on which relays I trigger first, which maybe says to me I am sending too much data and getting overflow into the next request.
I don't have a schematic for this board, but I am assuming they are wired something like the dual 74HC595 setup on this page, but I do not know. https://protostack.com.au/2010/05/intro ... g-16-leds/
Code: Select all// LCTech 16ch Relay board with 2x74HC595 shift registers - replicates close to out of box relay testing function
int latchPin = 12;  // Latch pin of 74HC595 is connected to Digital pin 5
int clockPin = 13; // Clock pin of 74HC595 is connected to Digital pin 6
int dataPin = 14;  // Data pin of 74HC595 is connected to Digital pin 4
int oePin = 5;    // oePin - not using this
void setup()
  // Set all the pins of 74HC595 as OUTPUT
  pinMode(latchPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  pinMode(oePin, OUTPUT);
  // Setup serial comms
void loop()
      Serial.println("Relay #16 = 0b0000");
      digitalWrite(latchPin, LOW);
      shiftOut(dataPin, clockPin, LSBFIRST, 0b0000);
      digitalWrite(latchPin, HIGH);
      delay(3000);
      Serial.println("Relay #8 = 0b0001");
      shiftOut(dataPin, clockPin, LSBFIRST, 0b0001);
      delay(3000);
Only other conversation around this board and 8266's I can find are here on the Home Assistant board
https://community.home-assistant.io/t/1 ... /368544/29
Any help would be grately appreciated.
The board:
By Matt SegFault
#93554
Matt SegFault wrote:Hi all,
void setup()
void loop()
      delay(3000);
      delay(3000);
The board:
Here is the end result, some working code that replicates the boards test function when it comes out of the box
Code: Select allint latchPin = 12;  // Latch pin of 74HC595 is connected to Digital pin 5
uint16_t Data ;
void setup()
void loop()
            Data = 0b0000000000000001;
      shiftOut(dataPin, clockPin, MSBFIRST, (Data >> 8));
      shiftOut(dataPin, clockPin, MSBFIRST, Data);
      delay(100);
            Data = 0b0000000000000011;
      delay(100);
            Data = 0b0000000000000111;
      delay(100);
            Data = 0b0000000000001111;
      delay(100);
            Data = 0b0000000000011111;
      delay(100);
            Data = 0b0000000000111111;
      delay(100);
            Data = 0b0000000001111111;
      delay(100);
            Data = 0b0000000011111111;
      delay(100);
            Data = 0b0000000111111111;
      delay(100);
            Data = 0b0000001111111111;
      delay(100);
            Data = 0b0000011111111111;
      delay(100);
            Data = 0b0000111111111111;
      delay(100);
            Data = 0b0001111111111111;
      delay(100);
            Data = 0b0011111111111111;
      delay(100);
            Data = 0b0111111111111111;
      delay(100);
            Data = 0b1111111111111111;
      delay(100);
            Data = 0b1111111111111110;
      delay(100);
            Data = 0b1111111111111100;
      delay(100);
            Data = 0b1111111111111000;
      delay(100);
            Data = 0b1111111111110000;
      delay(100);
            Data = 0b1111111111100000;
      delay(100);
            Data = 0b1111111111000000;
      delay(100);
            Data = 0b1111111110000000;
      delay(100);
            Data = 0b1111111100000000;
      delay(100);
            Data = 0b1111111000000000;
      delay(100);
            Data = 0b1111110000000000;
      delay(100);
            Data = 0b1111100000000000;
      delay(100);
            Data = 0b1111000000000000;
      delay(100);
            Data = 0b1110000000000000;
      delay(100);
            Data = 0b1100000000000000;
      delay(100);
            Data = 0b1000000000000000;
      delay(100);
            Data = 0b0000000000000000;
      delay(100);
