By vanillaguerilla970
#94253
Code: Select all/*
  GPS Position Logger
  gps-position-logger.ino
  Read GPS data from BN-220 or any serial GPS sensor
  Requires TinyGPS++ Library
  Save to SD or microSD card
  DroneBot Workshop 2021
// Include required libraries
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
#include <SPI.h>
#include <SD.h>
// GPS Connections
static const int RXPin = 4, TXPin = 3;
// GPS Baud rate (change if required)
static const uint32_t GPSBaud = 9600;
// SD Card Select pin
const int chipSelect = 8;
// Write LED
//const int recLED = 7;
// String to hold GPS data
String gpstext;
// GPS write delay counter variables
// Change gpsttlcount as required
int gpscount = 0;
int gpsttlcount = 30;
// TinyGPS++ object
TinyGPSPlus gps;
// SoftwareSerial connection to the GPS device
SoftwareSerial ss(RXPin, TXPin);
void setup()
  // Set LED pin as output
  //pinMode(recLED, OUTPUT);
  // Start Serial Monitor for debugging
  // Start SoftwareSerial
  ss.begin(GPSBaud);
  // Initialize SD card
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    //don't do anything more:
    while (1);
  Serial.println("card initialized.");
  // Blink LED so we know we are ready
//  digitalWrite(recLED, HIGH);
 // delay(500);
//  digitalWrite(recLED, LOW);
//  delay(500);
//  delay(500);
//  delay(500);
//  delay(500);
void loop()
  // Turn off LED
  // See if data available
  while (ss.available() > 0)
    if (gps.encode(ss.read()))
      // See if we have a complete GPS data string
      if (displayInfo() != "0")
        // Get GPS string
        gpstext = displayInfo();
        // Check GPS Count
        Serial.println(gpscount);
        if (gpscount == gpsttlcount) {
          // LED On to indicate data to write to SD card
          //Open the file on card for writing
          File dataFile = SD.open("gpslog.csv", FILE_WRITE);
          if (dataFile) {
            // If the file is available, write to it and close the file
            dataFile.println(gpstext);
            dataFile.close();
            // Serial print GPS string for debugging
            Serial.println(gpstext);
          // If the file isn't open print an error message for debugging
          else {
            Serial.println("error opening datalog.txt");
        // Increment GPS Count
        gpscount = gpscount + 1;
        if (gpscount > gpsttlcount) {
          gpscount = 0;
// Function to return GPS string
String displayInfo()
  // Define empty string to hold output
  String gpsdata = "";
  // Get latitude and longitude
  if (gps.location.isValid())
    gpsdata = String(gps.location.lat(), 6);
    gpsdata += (",");
    gpsdata += String(gps.location.lng(), 6);
    gpsdata += (",");
    return "0";
  // Get Date
  if (gps.date.isValid())
    gpsdata += String(gps.date.year());
    gpsdata += ("-");
    if (gps.date.month() < 10) gpsdata += ("0");
    gpsdata += String(gps.date.month());
    gpsdata += ("-");
    if (gps.date.day() < 10) gpsdata += ("0");
    gpsdata += String(gps.date.day());
    return "0";
  // Space between date and time
  gpsdata += (" ");
  // Get time
  if (gps.time.isValid())
    if (gps.time.hour() < 10) gpsdata += ("0");
    gpsdata += String(gps.time.hour());
    gpsdata += (":");
    if (gps.time.minute() < 10) gpsdata += ("0");
    gpsdata += String(gps.time.minute());
    gpsdata += (":");
    if (gps.time.second() < 10) gpsdata += ("0");
    gpsdata += String(gps.time.second());
    return "0";
  // Return completed string
  return gpsdata;
#94308 so i uploaded the code shown above and i get this from the serial monitor after i hook my gps and sd card reader up to it... the gps is a gt-u7, chinese knockoff of a very common one. when i plug the gps in via usb and open a serial monitor i get good gps sentences.
20:54:19.498 ->
3,rst cause:4, boot mode:(3,0)
20:54:19.498 ->
20:54:19.498 -> wdt reset
20:54:19.498 -> load 0x4010f000, len 3460, room 16
20:54:19.498 -> tail 4
20:54:19.498 -> chksum 0xcc
20:54:19.498 -> load 0x3fff20b8, len 40, room 4
20:54:19.531 -> chksum 0xc9
20:54:19.531 -> csum 0xc9
20:54:19.531 -> v0004c7a0
20:54:19.531 -> ~ld
