http connection refused error with esp8266
Posted: Thu Feb 15, 2018 6:24 am
hi everyone
i am getting a connection refused error and otherwise nothing is getting printed on the serial monitor.
help plz
#include <Arduino.h>
#include <ESP8266WiFiMulti.h>
#include <ESP8266HTTPClient.h>
#include <ArduinoJson.h>
#define USE_SERIAL Serial
int id,temp_id=0,i=0;
ESP8266WiFiMulti wifiMulti;
USE_SERIAL.begin(115200);
delay(100);
WiFi.mode(WIFI_STA);
wifiMulti.addAP("DIGISOL", "edot2018");
while (wifiMulti.run() != WL_CONNECTED) { // Wait for the Wi-Fi to connect: scan for Wi-Fi networks, and connect to the strongest of the networks above
delay(250);
HTTPClient http,http2;
http.begin("http://192.168.1.12/FlightStats/api/Flight/GetArrivingFlightsStatus/"); //HTTP
delay(250);
http2.begin("http://192.168.1.12/FlightStats/api/Flight/GetDepartingFlightsStatus/");
delay(250);
if(http.begin("http://192.168.1.12/FlightStats/api/Flight/GetArrivingFlightsStatus/") == false) {
USE_SERIAL.println("http.begin() failed");
exit(0);
//start connection and send HTTP header
int httpCode = http.GET();
int httpCode2 = http2.GET();
// [HTTP] GET... failed, error: connection refused
if(httpCode > 0 && httpCode2 > 0) {
// HTTP header has been send and Server response header has been handled
// file found at server
if(httpCode == HTTP_CODE_OK && httpCode2 == HTTP_CODE_OK) {
String myString = http.getString();
String myString2 = http2.getString();
const size_t bufferSize = JSON_OBJECT_SIZE(2) + JSON_OBJECT_SIZE(3) + JSON_OBJECT_SIZE(5) + JSON_OBJECT_SIZE(8) + 370;
DynamicJsonBuffer jsonBuffer(bufferSize);
JsonObject& root = jsonBuffer.parseObject(myString);
const char* descpription = root["Description"];
JsonObject& root1 = jsonBuffer.parseObject(myString2);
const char* descpription2 = root1["Description"];
if(i=0){
USE_SERIAL.println(descpription);
USE_SERIAL.println(descpription2);
i=1;
else {
USE_SERIAL.printf("[HTTP] GET... failed, error: %s\n", http.errorToString(httpCode).c_str());
http.end();
help plz
