By MKoehler
#16094 Hi,
I was wondering if I got the right firmware build with SDK 1.0.0 libs to get rid of zombie mode:
https://github.com/chadouming/nodemcu-f ... latest.bin
If I use this firmware, I get zombie mode after about 100 to 2000 restarts :roll: on a Wi07-12 module:
http://www.ebay.de/itm/ESP8266-serial-W ... 27f4939213
I am running another test on a standard Wi07-01 module with additional connection from GPIO16 to RESET to make restart possible. This test has not failed yet (about 4000 restarts so far and still running) using only 2 NIMH AA accus.
If it is the proper module do I have to use some specific flashing instructions? I use the latest NODEMCU Firmware Flasher with address 0*00000 for firmware_latest.bin
If anyone has a firmware the does not “zombify” please post a link. I would gladly test it thoroughly with some more complex programs.
Heinz-Georg
By delinend
#16156
Eyal wrote:
delinend wrote:Around 17.9K
Since you are building your own fw: I remove (#define->#undef) all unused modules in app/include/user_modules.h and gain many Ks of heap. YMMV
HTH
Hi Eyal.
Soory.. I can't build self. But I want to.. Do you know where to start? Can I use a Raspberry with GCC or do I have to use a Ubuntu? I think the best in the start, to get more Heap, is as you say to disable modules, that I'm not going to use.
The FW I have tested, was linked nicely from @Cal https://github.com/chadouming/nodemcu-firmware, and the dsleep work on that FW for me. But I have many cripts, that is to large for that FW.
Thanks and best regards
