Re: socket:send() chokes on larger data
Posted: Wed Dec 10, 2014 8:05 am
Hi,
socket:send() is a simple wrap for espconn_sent() in sdk.
socket:send()-->get string from para, check len<1460---> call espconn_sent() from sdk
-->call espconn_tcp_sent() if type=tcp--> call tcp_write() in lwip stack.
and never have a look at the lwip tcp_XXX raw api.
don't know how to flush them
the code espconn_tcp_sent and espconn_sent is included in sdk 0.9.2
which can be downloaded from
http://bbs.espressif.com/viewtopic.php?f=5&t=3
const char *payload = luaL_checklstring( L, 2, &l );
if (l>1460 || payload == NULL)
return luaL_error( L, "need <1460 payload" );
if(nud->secure)
espconn_secure_sent(pesp_conn, (unsigned char *)payload, l);
else
espconn_sent(pesp_conn, (unsigned char *)payload, l);
sint8 ICACHE_FLASH_ATTR
espconn_sent(struct espconn *espconn, uint8 *psent, uint16 length)
espconn_msg *pnode = NULL;
bool value = false;
if (espconn == NULL) {
return ESPCONN_ARG;
espconn ->state = ESPCONN_WRITE;
value = espconn_find_connection(espconn, &pnode);
switch (espconn ->type) {
case ESPCONN_TCP:
if (value)
espconn_tcp_sent(pnode, psent, length);
else
return ESPCONN_ARG;
break;
case ESPCONN_UDP: {
if (value)
espconn_udp_sent(pnode, psent, length);
else
return ESPCONN_ARG;
break;
default :
break;
return ESPCONN_OK;
void ICACHE_FLASH_ATTR
espconn_tcp_sent(void *arg, uint8 *psent, uint16 length)
espconn_msg *ptcp_sent = arg;
struct tcp_pcb *pcb = NULL;
err_t err = 0;
u16_t len = 0;
u8_t data_to_send = false;
espconn_printf("espconn_tcp_sent ptcp_sent %p psent %p length %d\n", ptcp_sent, psent, length);
if (ptcp_sent == NULL || psent == NULL || length == 0) {
return;
pcb = ptcp_sent->pcommon.pcb;
if (tcp_sndbuf(pcb) < length) {
len = tcp_sndbuf(pcb);
} else {
len = length;
LWIP_ASSERT("length did not fit into uint16!", (len == length));
if (len > (2 * pcb->mss)) {
len = 2 * pcb->mss;
do {
espconn_printf("espconn_tcp_sent writing %d bytes %p\n", len, pcb);
err = tcp_write(pcb, psent, len, 0);
if (err == ERR_MEM) {
len /= 2;
} while (err == ERR_MEM && len > 1);
if (err == ERR_OK) {
data_to_send = true;
ptcp_sent->pcommon.ptrbuf = psent + len;
ptcp_sent->pcommon.cntr = length - len;
espconn_printf("espconn_tcp_sent sending %d bytes\n", length);
if (data_to_send == true) {
err = tcp_output(pcb);
} else {
ptcp_sent->pespconn ->state = ESPCONN_CLOSE;
