Re: 7$ WiFi LED Dimmer/Fader with LUA on ESP8266
Posted: Thu Jun 25, 2015 6:00 pm
spy king wrote:I have one the COB style spots like on your blog (9w though). But when I try and dim it using a Mosfet (http://www.ti.com/lit/ds/symlink/csd18533kcs.pdf) I find that the supplied driver hums. Have you encountered something similar? The driver is a constant current type. Any ideas?
EDIT: After some more reading, it would seem that my 12k pull-down resistor was a bit much. Tried it with a 1.2k resistor and non as well, but seems I am having some issues. In theory, the mosfet should be able to dim a constant current supply as well right?
Ah no, I believe you will need a constant voltage power supply.
You need to measure the voltage the constant current supply is outputting at max brightness and then match that voltage with a constant voltage supply. Then using my dimmer design with mosfets you will be able to dimm to LEDs perfectly.
