Re: Network LED Dimmer/Fader with LUA on ESP8266
Posted: Mon Dec 29, 2014 3:29 am
Topic moved in Script examples.
Open Community Forum for ESP8266, Come share Arduino and IoT (Internet of Things)
https://www.esp8266.com/
And can you explain how you chose the MOSFETs and what power requirements you are working with?
pwm.setup(3, 1000, 005)
pwm.setup(5, 1000, 005)
pwm.setup(6, 1000, 005)
pwm.start(4)
pwm.start(5)
pwm.start(6)
LED1_current=005
LED1_target=005
LED2_current=005
LED2_target=005
LED3_current=005
LED3_target=005
Fadetime1=5000
Fadetime2=5000
Fadetime3=5000
Stepcounter1=0
PosStepcounter1=0
DimTimer1=0
Stepcounter2=0
PosStepcounter2=0
DimTimer2=0
Stepcounter3=0
PosStepcounter3=0
DimTimer3=0
wifi.setmode(wifi.STATION)
wifi.sta.config("SSID","PASSWORD")
srv=net.createServer(net.TCP)
srv:listen(43333,function(conn)
conn:on("receive",function(conn,payload)
print("Input:"..payload)
if string.find(payload,"LED1") then
LED1_target=tonumber(string.sub(payload, 13) )
print("Received LED1 Target Value: "..LED1_target)
Stepcounter1=(LED1_target)-(LED1_current)
if (Stepcounter1) < 0 then
PosStepcounter1=(Stepcounter1)*-1
else PosStepcounter1=(Stepcounter1)
end
if (PosStepcounter1) == 0 then
PosStepcounter1=(PosStepcounter1)+1
else PosStepcounter1=(PosStepcounter1)
end
DimTimer1=(Fadetime1)/(PosStepcounter1)
if (DimTimer1) == 0 then
DimTimer1=(DimTimer1)+1
else DimTimer1=(DimTimer1)
end
print (Fadetime1)
print (Stepcounter1)
print (PosStepcounter1)
print (DimTimer1)
print (LED1_current)
print (LED1_target)
tmr.alarm(0, (DimTimer1), 1, function()
if LED1_current < LED1_target then
LED1_current = (LED1_current + 1)
pwm.setduty(3, LED1_current)
elseif LED1_current > LED1_target then
LED1_current = (LED1_current - 1)
elseif LED1_current == LED1_target then tmr.stop(0)
end end )
end
if string.find(payload,"LED2") then
print("Received LED2 Target Value")
LED2_target=tonumber(string.sub(payload, 13) )
Stepcounter2=(LED2_target)-(LED2_current)
if (Stepcounter2) < 0 then
PosStepcounter2=(Stepcounter2)*-1
else PosStepcounter2=(Stepcounter2)
end
if (PosStepcounter2) == 0 then
PosStepcounter2=(PosStepcounter2)+1
else PosStepcounter2=(PosStepcounter2)
end
DimTimer2=(Fadetime2)/(PosStepcounter2)
if (DimTimer2) == 0 then
DimTimer2=(DimTimer2)+1
else DimTimer2=(DimTimer2)
end
print (Fadetime2)
print (Stepcounter2)
print (PosStepcounter2)
print (DimTimer2)
print (LED2_current)
print (LED2_target)
tmr.alarm(1, (DimTimer2), 1, function()
if LED2_current < LED2_target then
LED2_current = (LED2_current + 1)
pwm.setduty(5, LED2_current)
elseif LED2_current > LED2_target then
LED2_current = (LED2_current - 1)
elseif LED2_current == LED2_target then tmr.stop(1)
end end )
end
if string.find(payload,"LED3") then
LED3_target=tonumber(string.sub(payload, 13) )
print("Received LED3 Target Value: "..LED3_target)
Stepcounter3=(LED3_target)-(LED3_current)
if (Stepcounter3) < 0 then
PosStepcounter3=(Stepcounter3)*-1
else PosStepcounter3=(Stepcounter3)
end
if (PosStepcounter3) == 0 then
PosStepcounter3=(PosStepcounter3)+1
else PosStepcounter3=(PosStepcounter3)
end
DimTimer3=(Fadetime3)/(PosStepcounter3)
if (DimTimer3) == 0 then
DimTimer3=(DimTimer3)+1
else DimTimer3=(DimTimer3)
end
print (Fadetime3)
print (Stepcounter3)
print (PosStepcounter3)
print (DimTimer3)
print (LED3_current)
print (LED3_target)
tmr.alarm(2, (DimTimer1), 1, function()
if LED3_current < LED3_target then
LED3_current = (LED3_current + 1)
pwm.setduty(6, LED3_current)
elseif LED3_current > LED3_target then
LED3_current = (LED3_current - 1)
elseif LED3_current == LED3_target then tmr.stop(2)
end end )
end
end)
end)
print ("Booted to QuinLED_ESP8266_V0.4")
