By fahimhaider
#49288 Dear ALL
i want to read 2--4 ds18b20 but get only one ds18b20 value. Below are the lua module i load. Please help me to reolve this issue
local modname = ...
local M = {}
_G[modname] = M
-- Local used variables
-- DS18B20 dq pin
local pin = nil
-- DS18B20 default pin
local defaultPin = 1
-- Local used modules
-- Table module
local table = table
-- String module
local string = string
-- One wire module
local ow = ow
-- Timer module
local tmr = tmr
-- Limited to local environment
setfenv(1,M)
-- Implementation
C = 0
F = 1
K = 2
function setup(dq)
pin = dq
if(pin == nil) then
pin = defaultPin
ow.setup(pin)
function addrs()
setup(pin)
tbl = {}
ow.reset_search(pin)
repeat
addr = ow.search(pin)
if(addr ~= nil) then
table.insert(tbl, addr)
tmr.wdclr()
until (addr == nil)
return tbl
function readNumber(addr, unit)
result = nil
setup(pin)
flag = false
if(addr == nil) then
count = 0
repeat
count = count + 1
tmr.wdclr()
until((addr ~= nil) or (count > 100))
return result
crc = ow.crc8(string.sub(addr,1,7))
if (crc == addr:byte(8)) then
if ((addr:byte(1) == 0x10) or (addr:byte(1) == 0x28)) then
-- print("Device is a DS18S20 family device.")
ow.reset(pin)
ow.select(pin, addr)
ow.write(pin, 0x44, 1)
-- tmr.delay(1000000)
present = ow.reset(pin)
ow.write(pin,0xBE,1)
-- print("P="..present)
data = nil
data = string.char(ow.read(pin))
for i = 1, 8 do
data = data .. string.char(ow.read(pin))
-- print(data:byte(1,9))
crc = ow.crc8(string.sub(data,1,8))
-- print("CRC="..crc)
if (crc == data:byte(9)) then
t = (data:byte(1) + data:byte(2) * 256)
if (t > 32767) then
t = t - 65536
if (addr:byte(1) == 0x28) then
t = t * 625 -- DS18B20, 4 fractional bits
t = t * 5000 -- DS18S20, 1 fractional bit
if(unit == nil or unit == 'C') then
-- do nothing
--- elseif(unit == 'F') then
-- t = t * 1.8 + 320000
-- elseif(unit == 'K') then
-- t = t + 2731500
-- else
-- return nil
t = t / 10000
return t
tmr.wdclr()
-- print("Device family is not recognized.")
-- print("CRC is not valid!")
return result
function read(addr, unit)
t = readNumber(addr, unit)
if (t == nil) then
return nil
return t
-- Return module table
return M
And below are the reading code of ds
t=require("ds18b20_1")
pin = 1
t.setup(pin)
addrs = t.addrs()
if (addrs ~= nil) then
print("Total DS18B20 sensors: "..table.getn(addrs))
print("Temperature: "..t.read().."'C")
if (table.getn(addrs) >= 2) then
print("Second sensor: "..t.read(addrs[2],t.C).."'C")
t = nil
ds18b20 = nil
package.loaded["ds18b20_1"]=nil
By picstart
#49296 OK, I didn't look into the above code too deeply. For years ago I recall the one wire protocol can discover a single one wire device from among many. To discover all devices requires an entirely different routine. It was called discovery. To discover all devices the code needs to be written as either recursive or pseudo recursive. The devices sit on a binary tree and a single device is discovered by traversing the tree with a preference to go either left or right at each junction.Any device will at each branch either be a zero or a one. If there is more than one device then at some branch both a zero from at least one devices or a one from one from at least one device must occur. The recursive routine backs up and takes the 0 branch if it took the 1 branch backing up and down the tree until all branches are taken discovering every device that way.
By xtal
#49324 Havn't looked to much at your code, but did notice you wre playing with some data bits.
When I get the raw data temperature
1> Save sign bit , if neg do 2's comp
2> Multiply by [I think .0625 see data sheet] to get Celcius degrees m then apply sign bit...
Bit banging is difficult, You might want to look into LinkUSB adapter [about $30 us]
It uses serial commands, the bit banging is done in the adapter.....
To see all the DS18B20's you must do a 1-wire search ......
You may also to build a 1-wire sniffer , its bailed me out on 1-wire slave's I made...
