- Running windows 10
- ESPtool 0.2.0 rc2
- Erlang MQTT Broker 1.1.2 (http://emqtt.io/docs/index.html)
WEMOS D1 R2 (http://www.wemos.cc/Products/d1_r2.html) running:
- NodeMCU custom build by frightanic.com
branch: master
commit: c8037568571edb5c568c2f8231e4f8ce0683b883
SSL: true
modules: adc,bit,bmp085,cjson,coap,crypto,dht,enduser_setup,file,gpio,hx711,i2c,mqtt,net,node,ow,pwm,rc,rtcfifo,rtcmem,rtctime,sntp,spi,tmr,u8g,uart,wifi
build built on: 2016-02-25 14:44
powered by Lua 5.1.4 on SDK 1.4.0
I connect to my home wifi with:
- wifi.setmode(wifi.STATION)
wifi.sta.config("SSID","password") # yes with my SSID and password
print(wifi.sta.getip())
The print function above (of course) will return the IP address of the WEMOS board so I am happy the board is connecting with the wifi.
So, having checked the board is connected to wifi I then use a cutdown of the mqtt example from wikipedia being:
- m = mqtt.Client("clientid", 120, null, null)
m:lwt("/lwt", "offline", 0, 0)
m:on("connect", function(con) print ("connected") end)
m:on("offline", function(con) print ("offline") end)
m:connect("192.168.0.48", 1883, 0)
m:publish("hello","there",0,0)
m:close();
The error I get is:
- dofile("script2.lua")
script2.lua:21: not connected
stack traceback:
[C]: in function 'publish'
script2.lua:21: in main chunk
[C]: in function 'dofile'
stdin:1: in main chunk
I am running emqtt console and don't see a connection from the WEMOS. I am running both a node-red and paho python subscribe clients and I can subscrive with a node-red publisher. I see activity on the node-red and the paho-python client so I know that is all set up correctly.
But there is a quirk with the nodemcu I am not quite getting. Any hints please?
Cheers,
A
