bit Button = P0^0; // define port 0 >> 0 pin
bit Led = P0^1; // define output pin for led
void main (void)
Led = 0;
while(1)
if (Button == 0 ) // check that button is pressed or not
Led = ~Led;
using this code toggle led on and off with single button.
how to write same as in LUA?
what i actually want to do >>
led1 = 4
led2 = 6
led3 = 1
led4 = 2
gpio.mode(led1, gpio.OUTPUT)
gpio.mode(led2, gpio.OUTPUT)
gpio.mode(led3, gpio.OUTPUT)
gpio.mode(led4, gpio.OUTPUT)
srv=net.createServer(net.TCP)
srv:listen(5555,function(conn)
conn:on("receive", function(client,request)
local buf = "";
local _, _, method, path, vars = string.find(request, "([A-Z]+) (.+)?(.+) HTTP");
if(method == nil)then
_, _, method, path = string.find(request, "([A-Z]+) (.+) HTTP");
local _GET = {}
if (vars ~= nil)then
for k, v in string.gmatch(vars, "(%w+)=(%w+)&*") do
_GET[k] = v
buf = buf.."<h1>Relé WIFI </h1>";
buf = buf.."<p>PORTÃO <a href=\"?pin=ON1\"><button>ON</button></a> <a href=\"?pin=OFF1\"><button>OFF</button></a></p>";
buf = buf.."<p>LUZES 1 <a href=\"?pin=ON2\"><button>ON</button></a> <a href=\"?pin=OFF2\"><button>OFF</button></a></p>";
buf = buf.."<p>LUZES 2 <a href=\"?pin=ON3\"><button>ON</button></a> <a href=\"?pin=OFF3\"><button>OFF</button></a></p>";
buf = buf.."<p>LUZES 3 <a href=\"?pin=ON4\"><button>ON</button></a> <a href=\"?pin=OFF4\"><button>OFF</button></a></p>";
local _on,_off = "",""
if(_GET.pin == "OFF1")then
gpio.write(led1, gpio.HIGH);
elseif(_GET.pin == "ON1")then
gpio.write(led1, gpio.LOW);
tmr.delay(500000);
elseif(_GET.pin == "OFF2")then
gpio.write(led2, gpio.HIGH);
elseif(_GET.pin == "ON2")then
gpio.write(led2, gpio.LOW);
elseif(_GET.pin == "OFF3")then
gpio.write(led3, gpio.HIGH);
elseif(_GET.pin == "ON3")then
gpio.write(led3, gpio.LOW);
elseif(_GET.pin == "OFF4")then
gpio.write(led4, gpio.HIGH);
elseif(_GET.pin == "ON4")then
gpio.write(led4, gpio.LOW);
client:send(buf);
client:close();
collectgarbage();
end)
end)
using this code when i want to change the status of pin , press OFF or ON from browser ,
but using invert logic, payload of server is same but work is changed.
so how its done? any idea about invert logic in LUA....
other thing that i want to know that where i found conn:on srv:listen , client:send , client:close(); , collectgarbage(); GET{} POST - method
this type of documentation? i mean what parameters is used for call function for esp8266 web-server?
