To allow output from scripts to be printed to the 'run' page I added a redirect of outout so that it writes to the page.
if vars=="run" then
conn:send("<verbatim>")
function s_output(str)
if(conn~=nil)
then conn:send(str)
node.output(s_output, 0) -- re-direct output to function s_ouput.
local st, result=pcall(dofile, url)
node.output(nil)
conn:send(tostring(result))
First I had to delete the first lines which contain the [] tokens at the beginning of the program.
Next it gave a compile error:
stdin:1: '=' expected near '<'w([[ end ]]);
And that occured at the line where it says:
conn:send("<button onclick=\"tag('Saving');x.open('POST',location.pathname,true);\nx.onreadystatechange=function(){if(x.readyState==4) tag(x.responseText);};\nx.send(new Blob([document.getElementsByName('t')[0].value],{type:'text/plain'}));\">Save</button><a href='?run'>run</a><w></w>")
Anyone expieriencing the same problem.
As a result it also said:
> dofile("webedit.lua");
not enough memory
Any toughts ???
Update at October 4
Uploaded with Lualoder as described in previous post.
Program now works however the error code keeps appearing.
In the same line as above described.
Result:
The Save button is missing. So I am not able to save changes or new programs........
Luc
The mini Web IDE works beautifully for its intended purpose. But, I thought of adding an LED blinker to indicate that the ESP is in the Web IDE mode.
function blink()
gpio.write(3, gpio.HIGH)
tmr.delay(20000) -- wait 20,000 us = .02 second
gpio.write(3, gpio.LOW)
tmr.alarm(2,300,1,blink) -- Use timer2, every 300ms second
This works fine too. BUT, if I change the gpio to 4 (the actual pin on my ESP I'd like to put the LED on), it does not work.
The above routine works for both gpios if run by itself.
I dont see gpio 4 being used for anything else in the Web Ide, so I'm wondering where the problem is?
Any pointers would be highly appreciated, guys!
Regards.
