Using the analogy of an aircraft, consider X direction = out the right wing, Y direction = straight ahead, Z direction = upwards (ie, "ENU" notation). Nose down is negative pitch, nose up positive pitch. And left wing down is negative roll, left wing up positive roll.
The NodeMCU Lua math module has very limited functionality, only math.abs(), .ceil(), .floor(), .max(), .min(), .pow(), .random(), .randomseed(), .sqrt(), .huge and .pi. This is not enough to calculate pitch and roll easily.
But using the math.atan2() function included into E Suite
https://github.com/BLavery/esuite-lua
it becomes trivial. Using three accelerometer readings which we can call ax, ay, az, then roll and pitch are:
function roll(ax , az)
return - math.floor(math.atan2(ax, az)/math.rad)
-- in integer degrees
end
function pitch(ay , az)
return math.floor(math.atan2(ay, az)/math.rad)
end
The short functions for atan() and atan2() can be lifted easily from the E Suite files.
