Lua NodeMCU and Amazon IoT MQTT
Posted:
Wed Sep 13, 2017 2:53 pm
by stgoddv
Hi!
I think it would be extremely valuable if someone could post and example code connecting esp8266 nodemcu with IoT AWS Mqtt services. I've done research over internet but all the solutions that i've came across uses the C SDK presented by AWS or Mongoose or similar. But none of them uses properly MQTT NodeMCU Lua libraries to accomplish that. It's not straighforward in this case, because i think AWS needs some extra certificate logic before establishing the connection, as oppose to Azure (in that case the connection is straighforward and simple).
I'm sure that this example would be very useful for many people, especially the following years with the new powerful esp32 around. Has someone worked on this? Please post your code if so.. We'll appreciate that.
Any comments would help also, even if you don't have the code but have experience with this platforms.
Re: Lua NodeMCU and Amazon IoT MQTT
Posted:
Tue Oct 17, 2017 7:48 pm
by Dsbaha
Hi, the below is what I'm using. Seems stable. Have 23kb of heap left after the connection. I also have some wifi event manager things and other misc tasks running in the background.
Code: Select allm_dis={}
function reportshadow(m)
print("Reporting Shadow State")
ss = {}
ss.state = {}
ss.state.reported = {}
ss.state.reported.gpio = { gpio.read(3), gpio.read(4) }
m:publish("$aws/things/"..node.chipid().."/shadow/update", sjson.encode(ss), 0, 0)
ss = nil
end
function dispatch(m,t,pl)
if pl ~= nil and m_dis[t] then
m_dis[t](m,pl)
end
end
function topic1func(m,pl)
print("get1: "..pl)
end
function topic2func(m,pl)
node.input(pl)
end
function topic3func(m,pl)
print("get3: "..pl)
delta = sjson.decode(pl)
if delta.state.gpio[1] ~= nil then
print("GPIO0: " .. delta.state.gpio[1])
gpio.write(3, delta.state.gpio[1])
end
if delta.state.gpio[2] ~= nil then
print("GPIO2: " .. delta.state.gpio[2])
gpio.write(4, delta.state.gpio[2])
end
reportshadow(m)
end
m_dis["all/status"]=topic1func
m_dis[node.chipid() .. "/status"]=topic2func
m_dis["$aws/things/".. node.chipid() .."/shadow/update/delta"]=topic3func
m=mqtt.Client(node.chipid(), 1500, node.chipid(), node.chipid())
m:on("connect", function(m)
print("connected "..node.heap())
for k,v in pairs(m_dis) do
m:subscribe(k, 0)
end
reportshadow(m)
end)
m:on("offline", function(conn)
print("disconnected "..node.heap())
end)
--m:lwt("$aws/things/".. node.chipid() .."/shadow/update", sjson.encode(lwt))
m:on("message", dispatch)
tls.cert.auth(true)
tls.cert.verify(true)
gpio.mode(3, gpio.OUTPUT)
gpio.mode(4, gpio.OUTPUT)
m:connect("xxxxxx.iot.xxxxxx.amazonaws.com", 8883, 1, 0)
I should probably mention I use the following to get the device/ca certs in the module;
Code: Select alltls.cert.auth(
-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----
-----BEGIN RSA PRIVATE KEY-----
-----END RSA PRIVATE KEY-----
tls.cert.verify(
Posted:
Fri Dec 22, 2017 3:34 am
by stgoddv
Awesome!!!
Congrats! You're probably one of the few people that got this working.
I'll try your example to see how it goes. I'm sure that your code will benefit a lot of fellows.
Thanks!
Posted:
Fri Dec 22, 2017 7:54 pm
by stgoddv
Hi Dsbaha!
Thank you for the reply, very useful.
I'm getting the -5 error on connecting to AWS via your code.
Can you check if with the current master build, your code works well?
Please! Thanks!
One last question:
How did you configure in AWS IoT Hub that you id node.chipid() would have a password and a user
named node.chipid()?
Should this work too?:
m=mqtt.Client(node.chipid(), 1500)
Thank you very much!
