By zdebel
#24235 Hey guys, total LUA noob here.
I've written a module for SHT-11, feel free to use it and comment on it.
Attached is the module and an example script on how to use it.
Cheers!
SHT-11 module:
Code: Select alllocal moduleName = ...
local M = {}
_G[moduleName] = M
--table module
local table = table
--bit module
local bit = bit
--timer module
local tmr = tmr
--gpio module
local gpio = gpio
-- local environoment
setfenv(1, M)
local function set_sck(v)
    if (v == 1) then
        gpio.write(sck, gpio.HIGH)
        gpio.write(sck, gpio.LOW)
local function set_data(v)
    if (v == 1) then
        gpio.mode(data, gpio.INPUT)
        gpio.write(data, gpio.LOW)
        gpio.mode(data, gpio.OUTPUT)
local function start()
    set_data(1)
    set_sck(0)
    tmr.delay(1)
    set_sck(1)
    tmr.delay(1)
    set_data(0)
    tmr.delay(1)
    set_sck(0)
    tmr.delay(1)
    set_sck(1)
    tmr.delay(1)
    set_data(1)
    tmr.delay(1)
    set_sck(0)
local function reset()
    set_data(1)
    set_sck(0)
    for i = 0, 8 do
        set_sck(1)
        tmr.delay(1)
        set_sck(0)
        tmr.delay(1)
    start()
local function write(v)
    local c = v
    local ret
    for i = 0, 7 do
        if (bit.band(c, 0x80) ~= 0) then
            set_data(1)
            set_data(0)
        c = bit.lshift(c, 1)
        set_sck(1)
        tmr.delay(1)
        set_sck(0)
        tmr.delay(1)
    set_data(1)
    set_sck(1)
    tmr.delay(1)
    ret = gpio.read(data)
    set_sck(0)
    return ret
local function read(ack)
    local c = 0
    set_data(1)
    for i = 0, 7 do
        set_sck(1)
        tmr.delay(1)
        c = bit.bor(c, gpio.read(data))
        set_sck(0)
        tmr.delay(1)
    if (ack == 1) then
        set_data(0)
    set_sck(1)
    tmr.delay(1)
    set_sck(0)
    set_data(1)
    return c
function M.init(s, d)
    sck = s
    data = d
    gpio.mode(data, gpio.INPUT);
    gpio.mode(sck, gpio.OUTPUT);
function M.read_measurements()
    reset()
    start()
    --TODO: add ACK check
    write(0x03)
    set_data(1)
    --TODO: add timeout
    for i = 0, 65536 do
        if (gpio.read(data) == 0) then
            break
    t0 = read(1)
    t1 = read(1)
    --TODO: add crc checking
    t_crc = read(0)
    t = bit.lshift(t0, 8);
    t = bit.bor(t, t1)
    --t = t - 4010 --for 5V
    t = t - 3970 --for 3.5V
    start()
    write(0x05)
    set_data(1)
    --TODO: add timeout
    for i = 0, 65536 do
            break
    h0 = read(1)
    h1 = read(1)
    h_crc = read(0)
    h = bit.lshift(h0, 8);
    h = bit.bor(h, h1)
    --compensation magic part 1
    rh = 268 * h
    rh = rh / 256
    rh = -rh
    rh = rh + 24052
    rh = rh * h
    rh = rh - 1341391
    rh = rh / 65536
    --compensation magic part 2
    rh_true = 52 * h
    rh_true = 6554 + rh_true
    rh_true = rh_true * (t - 2500) / 100
    rh_true = rh_true / 65536
    rh_true = rh_true + rh
    return t, rh_true
return M
Usage example:
Code: Select allsht = require("sht11")
--clock on GPIO4, data on GPIO12
sht.init(2, 6)
t, h = sht.read_measurements()
print("Temp: " .. t / 100 .. "." .. t % 100)
print("Hum: " .. h / 10 .. "." .. h % 10 .. " %")
By tomto23
#43036 Hi and thanks for that code.
Unfortunately, I can't get it running; I'll only receive that error message:
?:0: attempt to index upvalue '?' (a nil value)
stack traceback:
?: in function '?'
?: in function 'read_measurements'
init.lua:4: in main chunk
[C]: in function 'dofile'
stdin:1: in main chunk
It is thrown when calling the read_measurements function. Init is running through.
Any idea, what I could do?
