aterocana wrote:Can I ask also the locations of certificates?
Certificates are not flashed, see https://nodemcu.readthedocs.io/en/maste ... certverify
Explore... Chat... Share...
marcelstoer wrote:aterocana wrote:Can I ask also the locations of certificates?
__attribute__((section(".clientcert.flash"))) unsigned char tls_client_cert_area[INTERNAL_FLASH_SECTOR_SIZE];
// Lua: tls.cert.auth(true / false | PEM data [, PEM data] )
static int tls_cert_auth(lua_State *L)
int enable;
uint32_t flash_offset = platform_flash_mapped2phys((uint32_t) &tls_client_cert_area[0]);
if ((flash_offset & 0xfff) || flash_offset > 0xff000 || INTERNAL_FLASH_SECTOR_SIZE != 0x1000) {
// THis should never happen
return luaL_error( L, "bad offset" );
if (lua_type(L, 1) == LUA_TSTRING) {
const char *types[3] = { "CERTIFICATE", "RSA PRIVATE KEY", NULL };
const char *names[2] = { "certificate", "private_key" };
const char *error = fill_page_with_pem(L, &tls_client_cert_area[0], flash_offset, types, names);
if (error) {
return luaL_error(L, error);
enable = 1;
} else {
enable = lua_toboolean(L, 1);
bool rc;
if (enable) {
// See if there is a cert there
if (tls_client_cert_area[0] == 0x00 || tls_client_cert_area[0] == 0xff) {
return luaL_error( L, "no certificates found" );
rc = espconn_secure_cert_req_enable(1, flash_offset / INTERNAL_FLASH_SECTOR_SIZE);
} else {
rc = espconn_secure_cert_req_disable(1);
lua_pushboolean(L, rc);
return 1;
