Still, I am getting there. It now takes me about 10sec to reimage my ESP application if its core is still functional -- or 60sec if it is broken and I need toI plug in the USB UART and bootstrap from a clean firmware level.
wasted my first day on lua and nodeMCU:
init.lua:
function SaveX(sErr)
if (sErr) then
print (sErr)
s.err = sErr
file.remove("x")
file.open("x","w+")
for k, v in pairs(s) do
file.writeline(k .. "=" .. v)
file.close()
collectgarbage()
--local iFail = 10
function wait_for_wifi_conn ( )
tmr.alarm (1, 1000, 1, function ( )
-- iFail = iFail -1
-- if (iFail == 0) then
-- SaveX("could not access "..s.ssid)
-- node.restart()
-- end
if wifi.sta.getip ( ) == nil then
-- print(iFail)
print(s.ssid)
tmr.stop (1)
print ("ip: " .. wifi.sta.getip ( ))
sk=net.createConnection(net.TCP, 0)
sk:on("receive", NewLua)
sk:connect(80,s.host)
sGet = "GET /".. s.path .. " HTTP/1.1\r\nHost: " .. s.domain .. "\r\nConnection: keep-alive\r\nAccept: */*\r\n\r\n"
print(sGet)
sk:send(sGet)
collectgarbage()
end)
function NewLua(sck,c)
local nStart, nEnd = string.find(c, "\n\n")
if (nEnde == nil) then
nStart, nEnd = string.find(c, "\r\n\r\n")
c = string.sub(c,nEnd+1)
print("lua length: "..string.len(c))
if (string.sub(c,0,5) ~= "--lua") then
SaveX(s.domain.."/"..s.path .. " does not begin with --lua")
node.restart()
return
file.remove("do.lua")
file.open("do.lua","w+")
file.writeline(c)
file.close()
node.compile("do.lua")
dofile("do.lua")
dofile("do.lc")
collectgarbage()
s = {ssid="", pwd="", host="", domain="", path="", err=""}
if (file.open("x",r)) then
local sF = file.read()
print("setting: "..sF)
file.close()
for k, v in string.gmatch(sF, "([%w.]+)=([%S ]+)") do
s[k] = v
print(k .. ": " .. v)
if ((s.err == "") and s.host and s.domain and s.path) then
wifi.setmode (wifi.STATION)
wifi.sta.config(s.ssid, s.pwd)
wifi.sta.autoconnect (1)
wifi.setmode(wifi.SOFTAP)
wifi.ap.config({ssid="node_"..node.chipid(), pwd=""})
srv=net.createServer(net.TCP)
print(wifi.sta.getip())
srv:listen(80,function(conn)
conn:on("receive", function(client,request)
local _, _, method, path, vars = string.find(request, "([A-Z]+) (.+)?(.+) HTTP");
if (vars ~= nil)then
for k, v in string.gmatch(vars, "(%w+)=([^&]*)&*") do
s[k],n = string.gsub(v,"%%2F","/")
print(k .. " = " .. s[k])
SaveX()
node.restart()
do
local buf =
"<html><body><form>" ..
"error: <input name=err value='"..s.err.."'/><br/>" ..
"<h2>access point:</h2>" ..
"SSID: <input name=ssid value='"..s.ssid.."'/><br/>" ..
"pwd: <input name=pwd value='"..s.pwd.."'/><br/>"
client:send(buf);
do
local buf =
"<h2>fetch lua:</h2>" ..
"ip: <input name=host value='"..s.host.."'/><br/>" ..
"domain: <input name=domain value='"..s.domain.."'/><br/>"
client:send(buf);
do
local buf =
"path: <input name=path value='"..s.path.."'/><br/>" ..
"<input type=submit value='submit'/></form></body></html>"
client:send(buf);
client:close();
collectgarbage();
end)
end)
the code checks a setting file "x" and if fully populated it downloads for example
host=81.169.145.148
domain=robosoft.de
path=do.lua
if the download does not begin with "--lua", an error message is saved to "x" and after restart init.lua starts it's own access point to update "x"
i am totally new to lua and nodeMCU always gets "out of memory" :-(
had to remove the timeout error while trying to connect to access point :-(
i guess this is only a RAM issue and the RAM could be freed before executing the downloaded lua file :-/
and all wifi stuff is not really reliable :-/
the file should be split in 2 or 3 files anyway. So that the downloaded lua code could check "once a day" for a new file to download.
lua and nodeMCU is a mess :-/
don't know if i will have the happiness to waste more time on this.
