Although there are now others around, your particular approach is very usefull in testing snippets.
Great Tool !!
Greetings
Francisco
Explore... Chat... Share...
FeK9 wrote:Erni wrote:Thanks for sharing scargill
I would like to try it but I can't unzip the tool when I download it.
Did you use some special zipping ?
I use ZipGenius, it usually works OK
Hi Erni...
Had a similar problem getting scargill's terminal working from his dropbox link.
I had to create a dropbox account to get it installed on my local Laptop.
@scargill, I like the simplicity of your terminal and it's interface with Lua & esp8266... Thx
