Page 1 of 4
New Web IDE - ChiliPeppr NodeMCU Workspace
PostPosted: Thu Feb 18, 2016 2:48 pm
by jlauer
Hey folks, I wanted to announce a new web IDE for NodeMCU.
http://chilipeppr.com/nodemcu
Video tour of ChiliPeppr NodeMCU Workspace
Why did I create this? ChiliPeppr is a full ecosystem for controlling hardware from software. Programming a device is just the first step. Once it's programmed, you typically need software to control the device as well. ChiliPeppr lets you easily create front-end interfaces to your devices. It is especially suited for controlling multiple devices at the same time.
Additionally, I was having problems using ESPlorer, which I think is a great program, but Java is not a great platform anymore. On my high-resolution display I could barely use ESPlorer. Also, ESPlorer seemed to always use 100% CPU and would kill my laptop battery. ChiliPeppr solves all that.
Please feel free to fork the workspace and add additional features as you see fit.
-John
Re: New Web IDE - ChiliPeppr NodeMCU Workspace
PostPosted: Fri Feb 19, 2016 2:28 am
by Mighty Max
Nice thing!
However, it does not work here (Firefox 44.0) on Windows 7
Debugger says (sorry, german language):
Quellübergreifende (Cross-Origin) Anfrage blockiert: Die Gleiche-Quelle-Regel verbietet das Lesen der externen Ressource auf http://i2dcui.appspot.com/geturl?url=ht ... how/light/. (Grund: CORS-Kopfzeile 'Access-Control-Allow-Origin' fehlt).
PostPosted: Fri Feb 19, 2016 7:47 pm
by jlauer
I just tried it out in Firefox 44 and it seems to work fine. Make sure you are not trying to load https:// but instead just use http:// when loading ChiliPeppr.
Here's a screenshot of it loading fine in Firefox
Mighty Max wrote:Nice thing!
PostPosted: Sat Feb 20, 2016 11:46 am
by AdrianM
Just giving your ChilliPeppr hardware fiddle a spin... big thanks for sharing.
in case it helps others, I had to re-boot after installing the Serial Port JSON Server before it would work. Nice application for this platform although there's a few issues I'm having - for example Upload>Run doesn't do what I expected i.e. allow me to browse to a .LUA file on my HD. Not sure how I would load previously prepared scripts... also, hitting Refresh on NodeMCU Files doesn't show the files already in the device (although the script appears in the serial port console).
