dnc40085 wrote:ESPlorer is just a glorified serial terminal, so it shouldn't be contributing to the problem.
Are you using the right pin number? (ex. gpio4=2 gpio.write(gpio4, gpio.HIGH)) if yes, then...
Have you tried a current build of the dev branch from nodemcu-build.com (Note: dev branch uses 115200 baud rate)?
Thank you, I'll have a look of that.
