By Qyuuu
#51816 Hi!
I have a problem in my project.
I tried to connect Smart Phone Hotspot with StationAp mode ESP8266 and station mode ESP8266.
This is stationAp mode ESP8266.
Code: Select all--init.lua
dofile("stationAp.lua")
dofile("webServer.lua")
Code: Select all--stationAp.lua
print("Ready to start soft ap AND station")
     local str=wifi.ap.getmac();
     local ssidTemp=string.format("%s%s%s",string.sub(str,10,11),string.sub(str,13,14),string.sub(str,16,17));
     wifi.setmode(wifi.STATIONAP)
     local cfg={}
     cfg.ssid="ESP8266_"..ssidTemp;
     cfg.pwd="1111111111"
     wifi.ap.config(cfg)
     cfg={}
     cfg.ip="192.168.10.1";
     cfg.netmask="255.255.255.0";
     cfg.gateway="172.20.10.1";
     wifi.ap.setip(cfg);
     wifi.sta.config("iPhone","sda342342")
     wifi.sta.connect()
     local cnt = 0
     gpio.mode(0,gpio.OUTPUT);
     tmr.alarm(0, 1000, 1, function()
         if (wifi.sta.getip() == nil) and (cnt < 20) then
             print("Trying Connect to Router, Waiting...")
             cnt = cnt + 1
                  if cnt%2==1 then gpio.write(0,gpio.LOW);
                  else gpio.write(0,gpio.HIGH); end
             tmr.stop(0);
             print("Soft AP started")
             print("Heep:(bytes)"..node.heap());
             print("MAC:"..wifi.ap.getmac().."\r\nIP:"..wifi.ap.getip());
             if (cnt < 20) then print("Conected to Router\r\nMAC:"..wifi.sta.getmac().."\r\nIP:"..wifi.sta.getip())
                 else print("Conected to Router Timeout")
             cnt = nil;cfg=nil;str=nil;ssidTemp=nil;
             collectgarbage()
     end)
Code: Select all--webServer.lua
-- a simple HTTP server
if srv~=nil then
  srv:close()     --close the Server
pin = 5 -- dht11 signal pin
srv = net.createServer(net.TCP)
srv:listen(80, function(conn)
    status, temp, humi, temp_dec, humi_dec = dht.read(pin)
    CDS= adc.read(0)
    if status == dht.OK then
        temp_1 = math.floor(temp)
        humi_1 = math.floor(humi)
    elseif status == dht.ERROR_CHECKSUM then
        print( "DHT Checksum error." )
    elseif status == dht.ERROR_TIMEOUT then
        print( "DHT timed out." )
    tmr.delay(1000000)
    conn:on("receive", function(sck, payload)
        print(payload)
        sck:send("HTTP/1.0 200 OK\r\nContent-Type: text/html\r\n\r\n<h1>Temperature & Humidity<br/></h1>" .. "<br/><h1>Temperature = " .. temp .. "C</hr>" .. "<br/><h1>Humidity = " .. humi .. "%</hr></br><h1>CDS=" .. CDS .. "</hr>")
    end)
    conn:on("sent", function(sck) sck:close() end)
    print("CDS="..CDS)
    tmr.delay(1000000)
end)
print("webserver ready...")
This is station ESP8266 code
dofile("aaa.lua")
Code: Select all--aaa.lua
function connect()
    if(wifi.sta.status()==5)then
        socket=net.createConnection(net.TCP, 0)
        socket:connect(80,"192.168.10.2")
        socket:on("receive",function(sck, c)  print(c) end)
        socket:send("hello world!!")
local pin=7
gpio.mode(pin,gpio.OUTPUT)
wifi.setmode(wifi.STATION)
if(wifi.getmode()==1)then
    print("connecting station mode")
    wifi.sta.config("ESP8266_ce9d34","1111111111")
    wifi.sta.connect()
     tmr.alarm(0, 5000, 0, function()
        if(wifi.sta.getip()~=nil)then
        print(wifi.sta.getip())
        gpio.write(pin,gpio.HIGH)
        print(wifi.sta.status())
        connect()
        print(tmr.now())
        print("AP not exiest!!")
    end )
    if(wifi.sta.getip()==nil)then
if srv~=nil then
    CDS= adc.read(0)
    tmr.delay(1000000)
        print(payload)
        sck:send("HTTP/1.0 200 OK\r\nContent-Type: text/html\r\n\r\n<h1>My House Temperature & Humidity<br/></h1>" .. "<br/><h1>Temperature = " .. temp .. "C</hr>" .. "<br/><h1>Humidity = " .. humi .. "%</hr></br><h1>CDS=" .. CDS .. "</hr>")
    end)
    print("CDS="..CDS)
    tmr.delay(1000000)
end)
