By KevinA
#57374 Buried in the Junk folder! I can not find why they ended up there, checked all the rules, moves and server setting. The only thing I found was "1.0 KAM_LAZY_DOMAIN_SECURITY Sending domain does not have any
anti-forgery methods X-Spam-Flag: NO"
and that didn't cause the mail to go to junk...
I think I was going to check the web server junk box when they went down the other night and blew it off since.
Thanks
By jeroenh
#57434
You also need to flash the esp init data to the correct memory address as per http://nodemcu.readthedocs.io/en/master ... g-firmware.
See here as well: http://stackoverflow.com/a/38793023/131929
That is not immediately obvious from either the nodemcu-build.com webpage and/or the firmware filenames. It might help to make this a bit more clear to know which version the firmwares are.
Also, I see that the WS2812 library changed completely. Is it possible to get the older one also as an alternative?
By marcelstoer
#57480
jeroenh wrote:That is not immediately obvious from either the nodemcu-build.com webpage and/or the firmware filenames. It might help to make this a bit more clear to know which version the firmwares are.
True I'm biased as I work with this stuff every day but I'd still argue that it's very obvious because:
  • the filename contains the branch name prominently
  • the emails you get from the build service contains links to the NodeMCU docs for the selected branch
  • the NodeMCU docs are a distinct set of files for each branch, the URL contains the branch name
  • when you boot the firmware it tells you branch, modules, build date, etc.
By vcch
#57492 The instructions are quite clear for Nodemcu flasher, but i had problems flashing lower size flash chips.
Are there other configurations except the 1 MB setting in flash size ? Usually it worked with a 0X00000 and 0X10000 .bins, but the latest docker does not seem to generate them anymore...
