Problem with HTTP module and https
Posted: Fri Mar 24, 2017 6:49 pm
Hello!
I am trying to communicate nodemcu to the Telegram Bots Api (https://core.telegram.org/bots/api) and I need to use https.
I have tried with the stable branch, dev, compiled with docker, cloud... but I get always a
I use the same code in all tests I have done:
This is what I get in 2.0.0 stable with ssl enabled and in dev with ssl enabled too:
I am a little frustrated about this because I don't see anywhere people with this error and I don't know more things to try, sure this is a foolishness but I do not see it
Thanks in advance!
HTTP client: Connection timeout
http.get("https://telegram.me", nil, function(code, data)
if (code < 0) then
print("HTTP request failed")
else
print(code, data)
end
end)
HTTP client: Disconnected with error: -114
Thanks in advance!
