By hbouzas
#18310 Forget the DHT11. Implementing the protocol to read temperature and humidity eats all your memory on the ESP8266 and there is nothing left if you want to support MQTT messaging. However, and I2C sensor works. The I2C implementation using an LM75A can be done and integrated with MQTT.
I am preparing a post with the details on what I did and will publish in http://www.horaciobouzas.com
By trackerj
#18311
hbouzas wrote:Forget the DHT11. Implementing the protocol to read temperature and humidity eats all your memory on the ESP8266 and there is nothing left if you want to support MQTT messaging. However, and I2C sensor works. The I2C implementation using an LM75A can be done and integrated with MQTT.
You have already drivers for LM75 and more accurate MCP9808 here, might help:
LM75 I2C Driver
MCP9808 I2C Driver
Examples:
LM75
MCP9808
