By sohialsadiq
#26684 Hi,
i am new in nodemcu ,can anyone help how to use nodemcu 12E in Explorer IDE. i try many
time Flasher bin file as attached, i also try other bin file from GitHub nodemcu firmware.
but every time i open Explorer i get this message Can't autodetect firmware, because proper answer not received.
By JeremiahLandi
#33986 I'm in the same boat. I followed the instructions from:
https://www.youtube.com/watch?v=cOnPWltYtQs
Pushed the prog button then reset. I am using the nodemcu/nodemcu-flasher (https://github.com/nodemcu/nodemcu-flasher).
Code: Select allNote:Detect serial port changed.
Note:Auto MAP serial port.Port-->COM3
Note:Serial port connected.
Note:Begin find ESP8266.
Note:Serial port disconnected.
Warning:Serial port closed by user.
Note:Auto MAP serial port.Port-->COM5
Note:ESP8266 ACK success.
Note:Set base address success.
Note:Program flash success.
I used putty and dove into the system before pushing the reset. Upon reset I got the following in the putty screen:
Code: Select all0▒~?▒4▒R▒▒▒OI:▒COCE▒!▒▒OCA▒▒▒▒
NodeMCU 0.9.5 build 20150318  powered by Lua 5.1.4
lua: cannot open init.lua
I am running the baud rate at 9600 when connecting to the device but getting the same message from ESPlorer v0.2.0-rc2.
Code: Select all>
PORT CLOSED
PORT OPEN 9600
Communication with MCU...
Got answer! AutoDetect firmware...
> 0‚~?–4“R¶£ÿOI:¶COCE’!†üOCA
Did you end up getting an answer or resolving your problem?
Edit: Added more details.
Last edited by JeremiahLandi on Sat Nov 14, 2015 5:10 pm, edited 2 times in total.
By forlotto
#33990 There are 2 buttons up top labeled DTR and RTS
put both of them on
then click DTR once more to turn it OFF
then click DTR once more to turn it back on.
If you loop your esp with code flash back and forth from intager to float this will solve the loop init.lua will not be loaded so just format and wait for it to complete after reflashing.
So if you are on integer flash to float and open esplorer and click the format button
If you are on float flash to integer and open esplorer and click the format button
I normally use frightitanic builds cause you can select only the modules you need for the esp AKA custom.
Anyhow enjoy and welcome aboard.
By JeremiahLandi
#33993 So i followed the steps and got the following feedback in the system window.
Code: Select allPORT OPEN 9600
stdin:1: unexpected symbol near 'char(3)'
Here are my settings from the top.
http://imgur.com/u0gcjET
