Now I will add a resistor divider and use it to shut down when the LiPo battery drops to 2.7 volts.
Just what I needed!
Peter
Explore... Chat... Share...
gwizz wrote:I was planning to use exactly that sort of thing to monitor battery voltages also!
2.7V sounds a bit low for cut-off for LiPo cells, I would cut off at 3V at absolute minimum - 3.2V is used by batteries with their own built in charge management chips. So for maximum battery life I would play safe and use 3.2V - the only case for going lower is in a quadcopter or something where you need to get back to earth and it is better to damage the batteries than cut-off power!!
