Nevertheless, if I disconnect the a/p from the server (my gw) then after a few minutes I only get to status 3. When I reconnect the server the status soon progresses to 5 (STA_GOTIP).
I expected that once I associate with the a/p I instantly progress to STA_GOTIP status.
Why is this important? My app reads a sensor and sends a packet in under 500ms (usually). As it is now, when the server is down, a long timeout is incurred (about 5 seconds) which drains the battery 10 times faster.
The timeout is required to deal with intermittent a/p connection failures, but is unacceptable as a regular event.
I could run something like this
wifi.sta.disconnect()
wifi.sta.setip({ip="192.168.2.30",netmask="255.255.255.0",gateway="192.168.2.7"})
wifi.sta.config("SSID", "PASS", 1)
wifi.setmode(wifi.STATION)
wifi.sta.autoconnect(1)
and I can then check that everything is set:
print(wifi.sta.status(), wifi.sta.getip())
=wifi.sta.getconfig()
The status shows 3 when the gateway is disconnected.
TIA
