Re: nodemcu mqtt client
Posted: Mon Dec 05, 2016 10:24 am
An old thread for an answer for sure.
Just in case someone redirect here from google, here is my solution.
Using timer at bottom of the script, to check wifi connection, if lost, reset the mqtt object, then reconnect.
Here is my mqtt_init function:
tmr.alarm(1, 3000, 1, function()
if DEBUG then
print('IP: ',wifi.sta.getip())
end
if wifi.sta.getip() == nil then
restart = true
else
if restart == true then
restart = false
m = nil
mqtt_init()
connect()
end
end
end)
local function mqtt_init()
m = mqtt.Client(chipId, 5)
m:lwt("events/esp8266/".. chipId .."/status",
cjson.encode({
type = "status",
sensorId = chipId,
status = 0
}), 0, 0)
m:on("offline", function(m)
if DEBUG then
print ("Connecting to the broker ...")
end
end)
m:on("connect", function(m)
if DEBUG then
print("connected")
end
m:publish("events/esp8266/".. chipId .."/status",
cjson.encode({
type = "status",
sensorId = chipId,
status = 1,
heap = node.heap()
}), 0, 0)
m:subscribe("mcu/cmd/#", 0, function(m)
if DEBUG then
print("subscribed")
end
end)
end)
--m:on("message", switch_relay)
m:on("message", function() print ("relay switched") end)
end
local function connect()
m:connect(mqttHost, 1883, 0, 1)
end
