Bit-Banging, Performance, and Lua Table Lookups
Posted: Fri Dec 12, 2014 3:52 pm
Hi,
just in case someone is interrested, I'd like to share my findings on improving the performance on pin toggling used e.g. when bit-banging some data:
The screen shot above shows some measurements I made with my Logic Pirate. The corresponding Lua code is shown below:
As one would expect, table lookups make things quite slow. The 1st loop has two lookups per pin state change, taking about 100 us. In the 2nd loop, when eliminating the lookup for gpio.HIGH and gpio.LOW and using 1 and 0 instead, the speed roughly doubles to 50 us. The 3rd loop uses a variable instead of the table lookup for gpio.write which leads to about 11 us, and in the 4th loop the variable lookup for pin is also eliminated shaving off another us.
So from 100 us to 10 us is quite some improvement, I would say
Cheers and have fun,
Markus
pin = 9 -- 8 .. GPIO 0, 9 .. GPIO 2
gpio.mode(pin, gpio.OUTPUT)
-- 1
for i = 1, 2 do
gpio.write(pin, gpio.HIGH)
gpio.write(pin, gpio.LOW)
end
-- 2
for i = 1, 2 do
gpio.write(pin, 1)
gpio.write(pin, 0)
end
-- 3
gpio_write = gpio.write
for i = 1, 2 do
gpio_write(pin, 1)
gpio_write(pin, 0)
end
-- 4
for i = 1, 2 do
gpio_write(9, 1)
gpio_write(9, 0)
end
Markus
