Re: This is how to install without replacing your existing I
Posted:
Thu Apr 02, 2015 6:41 pm
by DangeRuss
Thanks, Roger. This works great, but I ran into some trouble getting the mDNS example working. I'd like to be able to disconnect the ESP from my computer and connect to it by esp8266.local, but I haven't had any success, even on multiple different networks. Any ideas what could be going wrong?
Thanks,
-Russ
Posted:
Fri Apr 03, 2015 2:44 am
by yuriy
Hi
Can someone help?
Arduino: 1.6.2 (Windows 7), Board: "Generic ESP8266 board"
Using library ESP8266WiFi in folder: C:\Users\XXX\Documents\Arduino\hardware\esp8266com\esp8266\libraries\ESP8266WiFi
Using library ESP8266WebServer in folder: C:\Users\XXX\Documents\Arduino\hardware\esp8266com\esp8266\libraries\ESP8266WebServer
C:\Program Files (x86)\Arduino/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -IC:\Program Files (x86)\Arduino/hardware/tools/esp8266/sdk//include -c -Os -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10602 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -IC:\Users\XXX\Documents\Arduino\hardware\esp8266com\esp8266\cores\esp8266 -IC:\Users\XXX\Documents\Arduino\hardware\esp8266com\esp8266\variants\esp01 -IC:\Users\XXX\Documents\Arduino\hardware\esp8266com\esp8266\libraries\ESP8266WiFi\src -IC:\Users\XXX\Documents\Arduino\hardware\esp8266com\esp8266\libraries\ESP8266WebServer\src C:\Users\XXX\AppData\Local\Temp\build7392467019008701898.tmp\HelloServer.cpp -o C:\Users\XXX\AppData\Local\Temp\build7392467019008701898.tmp\HelloServer.cpp.o
Error compiling.
Posted:
Fri Apr 03, 2015 4:58 am
by JohnHJ
I followed the instructions, ESP8266 appeared in Boards selection, but esptool did not.
I am using Arduino 1.6.2
