Arduino <-UART-> ESP8266 <-WIFI-> ROUTER <-WIFI-> Computer
Posted: Mon May 29, 2017 6:13 am
Hi all,
I would like to use an ESP8266 to avoid cables !
So here are my specifications :
- not change my previous Arduino codes -> UART
- as fast as possible (of course)
- reliable (of course again)
- avoid the use of external app -> only arduino IDE + libraries
- TCP for data transmission check (so no UDP)
The system would like :
Arduino <---UART---> ESP8266 <---WIFI---> ROUTER <---WIFI---> Computer
So i tried, and tried, an tried again to modify several codes I found on the web.
I have something not too bad. I am able to:
- send data from Arduino to ESP via UART (9600 bauds)
- send data from ESP to Computer via existing WIFI
- receive data from Computer to ESP via the same existing WIFI
- soon receive data from ESP to Arduino via UART
But at this point, I can already notice that wifi slows down and even lag.
To check my program, instead of hooking futur sensors, I'm generating a signal on Arduino.
It's a basic ascending and descending integer from 0 to 1024.
At each loop, I try to send it to the computer.
I notice that the first seconds, from 2 sec to 10 sec, everything is fine.
The signal received via wifi is visualised on MaxMSP and is good.
But after a while, I notice that there is randomly half second lags and a slower reception of the data.
NB :
1) I tried with a real router and my phone as an Access Point -> same results
2) ESP8266-12
3) UART connection over 9600 bauds between ESP and Arduino looks unstable. If someone has an idea to improve it....
I give you my full code and screen shots. I would pleased if it can be used by someone else and improved for the community benefits.
Arduino code:
ESP code:
NB :
2) ESP8266-12
Arduino code:
// ARD UNO ESP8266
// D10 <-> TX // Unhook before upload sketch
// D11 <-> RX // Unhook before upload sketch
// GND <-> GND
#include <SoftwareSerial.h>
#define RXpin 10 // MOD
#define TXpin 11 // MOD
String UARTsendData; // AUTO
SoftwareSerial espSerial(RXpin, TXpin);
void setup() { // -----------------------------------------------------------------------
Serial.begin(57600); // For com with computer
espSerial.begin(9600); // For com with ESP
void loop() { // ------------------------------------------------------------------------
// Generating a triangle wave forms
for (int i = 0; i < 1024; i++) {
UARTsendData = i;
UARTsend();
for (int i = 1023; i > 0; i--) {
UARTsendData = i;
UARTsend();
void UARTsend() { // --------------------------------------------------------------------
espSerial.print(UARTsendData);
espSerial.println("F");
ESP code:
// ARD UNO ESP8266
// GND <-> GND
#define RcvCount 10
#define Tempo 1
const char* ssid = "Z3K"; // MOD
const char* pwd = "pwd"; // MOD
const char* hostIP = "192.168.43.220"; // MOD
const int sendPort = 8889; // MOD
const int recvPort = 8890; // MOD
String UARTrcvData; // AUTO
char UARTrcvBuffer; // AUTO
int UARTrcvCount; // AUTO
String WIFIsendData; // AUTO
String WIFIrcvData; // AUTO
char WIFIrcvBuffer; // AUTO
int WIFIrcvCount; // AUTO
WiFiServer server(recvPort);
WiFiClient client;
Serial.begin(9600); // For com with ARD
WIFIconnect();
WIFIserverConnect();
server.begin();
client.setNoDelay(1);
Serial.println("\nInitialized");
UARTreceive();
WIFIsendData = UARTrcvData;
WIFIsend();
WIFIreceive();
void WIFIconnect() { // ----------------------------------------------------------------
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, pwd);
delay(Tempo);
void WIFIserverConnect() { // ----------------------------------------------------------
if (!client.connect(hostIP, sendPort)) {
void WIFIreceive() { // ----------------------------------------------------------------
WIFIrcvCount = 0;
WIFIrcvBuffer = 'N';
WIFIrcvData = "";
if (client.connected()) {
while (WIFIrcvBuffer != 'F' && WIFIrcvCount < RcvCount) {
WIFIrcvBuffer = client.read();
if (WIFIrcvBuffer != 'F') {
WIFIrcvData += WIFIrcvBuffer;
WIFIrcvCount++;
if (debug == true) {
Serial.println(WIFIrcvData);
client.flush();
void WIFIsend() { // -------------------------------------------------------------------
if (WiFi.status() != WL_CONNECTED) {
WIFIconnect();
client.flush();
client.println(WIFIsendData);
void UARTreceive() { // ----------------------------------------------------------------
UARTrcvCount = 0;
UARTrcvBuffer == 'N';
UARTrcvData = "";
while (UARTrcvBuffer != 'F' && UARTrcvCount < RcvCount) {
while (Serial.available() > 0) {
UARTrcvCount = UARTrcvCount + 1;
UARTrcvBuffer = (char)Serial.read();
if (UARTrcvBuffer != 'F') {
UARTrcvData += UARTrcvBuffer;
