By jtheires@netins.net
#14308 Just installed the new Arduino IDE (v1.6.1 p1) that I read eagerly about on LinkedIn (https://www.linkedin.com/groups/Getting ... re-0-b-ttl).
Installation completed without issue.
Compiling the example WiFiWebServer sketch works fine (no errors).
However, when I attempt to upload the example WiFiwebServer sketch, the Arduino IDE reports the following message:
Sketch uses 208,184 bytes (39%) of program storage space. Maximum is 524,288 bytes.
warning: espcomm_sync failed
error: espcomm_open failed
Hardware:
esp8266-01 (also tried with -07 module) connected to FTDI module as follows (and verified with DVM):
VCC ----> 3.3V Power supply (separate supply)
GND ----> Ground of power supply
CH_PD ----> HIGH (3.3V)
GPIO2 ----> HIGH (3.3V)
GPIO15 ----> LOW (GND)
GPIO0 ----> HIGH (3.3V)
Other pins open (floating).
Also attempted to reset the 8266 with REST pin to ground momentarily.
Also swapped Tx/Rx connections to FTDI module, and received a longer/uglier error message.
Also attempted to communicate with 8266-07 through an Arduino Uno, in order to rule out my FTDI module (and recently downloaded driver software upgrade)...same error/warning messages.
Has anyone resolved this issue?
