By dominator99
#50037 martinayotte
I've tried your code 'MyAPServer' & 'MyAPClient' today on 2 Adafruit Huzzah boards & the AP seems to start OK
Configuring Access Point ...
AP IP address: 192.168.4.1
HTTP server started
but the client returns:
onnecting to MyESPAP
WiFi connected
IP address:
192.168.4.2
connecting to 192.168.4.1
connection failed
connection failed
connection failed
connection failed
etc
I've not changed your sketches at all; any suggestions?
By martinayotte
#50041 My examples are quite outdated, they were done one year ago.
At that time, the Arduino framework had some default behaviours which probably changed.
You need to make sure the the MyAPClient is really in STA mode only (not STA+AP).
To do that simply add "WiFi.mode(WIFI_STA);" just before the the WiFi.begin().
This will avoid the client trying to connect to itself, since 192.168.4.1 is also present on the client when the mode is WIFI_AP_STA.
