Chat here is you are connecting ESP-xx type modules to existing AVR based Arduino
By abdurino
#32864 Connected GSM Neoway M590.
With external power 5V its work perfect on Arduino Uno, but same not work properly in ESP8266.
Neoway M590:
edge 1 - 5V external,
2 - gnd external+gnd esp8266,
7 - gsm TX->gpio 12
8 - gsm RX->gpio 13
At commands ok, register in network ok, sometime send sms )
but not receive sms and after some time module not respond or unregister network.
Tried connect TTL 5V->3.3V on RX/TX, but in this case not work even at commands.
Any ideas? May be somebody already solve all problems by this module?
Softwareserial library in attach.
+70001111111 replace on your phone.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(12, 13); // RX, TX (7 tx->12) (8 rx -> 13)
  Serial.begin(9600);  //скорость порта
  Serial.println("GSM tester v1.0");
  mySerial.begin(9600);
  String str;
  if (mySerial.available()) {  //если GSM модуль что-то послал нам, то
    str = mySerial.readStringUntil('\n');
    Serial.println(str);
  if (Serial.available() > 0) {
    str = Serial.readStringUntil('\n');
    if (str =="send sms") {
      send_sms("+70001111111", "test sms");
    } else {
      //Serial.println("at command");
      mySerial.println(str);
    //Serial.println(str);
void send_sms(String phone, String text) {
  mySerial.println("AT+CMGS=\"" + phone + "\"");
  mySerial.print(text);
  mySerial.print((char)26);
  readModem();
  Serial.println("SMS send complete");
  delay(2000);
void readModem() {
  String str;
