By Silux
#41821
electronrancher wrote:Sure, this works fine.
1) Plug NodeMCU into PC, install driver if needed. Remember what serial port it represents
2) Put NodeMCU into firmware upload mode: Hold RST and FLASH buttons, Release RST, Release FLASH.
3) Configure Arduino (Tools menu) to NodeMCU board, your serial port, flash size, etc.
4) Upload sketch.
Now your NodeMCU is flashed with your Arduino sketch. To make it a NodeMCU again, just get the NodeMCU flasher, which will come with the latest NodeMCU firmware bundled in it.
It works also for ESP8266 serial WIFI Witty cloud MINI nodemcu, which is a little cute square board with a RGB led and a photoresistor built in.
By Mike Lo
#41841 here is what I have received from Arduino IDE
esptool v0.4.4 - (c) 2014 Ch. Klippel <ck@atelier-klippel.de>
setting board to ck
setting baudrate from 115200 to 115200
setting port from /dev/tty.usbserial to /dev/cu.SLAB_USBtoUART
setting address from 0x00000000 to 0x00000000
espcomm_upload_file
stat /var/folders/_n/0t1_bg117lj9krbtsfxy010m0000gn/T/build5368536523334801012.tmp/Blink.cpp_00000.bin success
opening port /dev/cu.SLAB_USBtoUART at 115200
tcgetattr
tcsetattr
serial open
opening bootloader
resetting board
trying to connect
setting character timeout 0
done
setting character timeout 1
done
espcomm_send_command: sending command header
espcomm_send_command: sending command payload
espcomm_send_command: receiving 2013 bytes of data
error: failed reading byte
warning: espcomm_send_command: cant receive slip payload data
trying to connect
done
done
trying to connect
done
done
resetting board
trying to connect
done
done
trying to connect
done
done
trying to connect
done
done
resetting board
trying to connect
done
done
trying to connect
done
done
trying to connect
done
done
warning: espcomm_sync failed
error: espcomm_open failed
