HTTP OTA update failing
Posted: Mon Sep 05, 2016 10:51 pm
I am trying to get the OTA updating working, but it's in a crash loop. It fails like this every time it runs, Any advice you can offer would be greatly appreciated. I put the update check in the setup function:
attempting HTTP update...
tail 8
chksum 0x2d
csum 0x2d
v60000318
@cp:0
ld
This is the bin file - it's a tomcat webserver but the browser downloads it sucessfully: http://u.synaptrix.com/spooky.bin
Here are the compile stats:
Sketch uses 343,982 bytes (32%) of program storage space. Maximum is 1,044,464 bytes.
Global variables use 38,292 bytes (46%) of dynamic memory, leaving 43,628 bytes for local variables. Maximum is 81,920 bytes.
I'm a hack and it often takes a lot of work to get things working - please forgive the ugly code. I'll clean it up later.
tail 8
chksum 0x2d
csum 0x2d
v60000318
@cp:0
ld
#include <ESP8266HTTPClient.h>
#include <ESP8266httpUpdate.h>
#include <Wire.h>
#include <SHT21.h>
#include <Adafruit_Sensor.h>
#include "Adafruit_MCP23008.h"
#include "Adafruit_TSL2591.h"
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h> //https://github.com/tzapu/WiFiManager
//for LED status
#include <Ticker.h>
#include "SparkFunMPL3115A2.h"
#include "sensors.h"
//initialize
Ticker ticker;
Adafruit_MCP23008 mcp;
Adafruit_TSL2591 tsl = Adafruit_TSL2591(2591); // pass in a number for the sensor identifier (for your use later)
//Baro
MPL3115A2 myPressure;
// Create an ESP8266 WiFiClient class to connect to the MQTT server.
WiFiClient client;
HTTPClient http;
int redirectTimeout = 10000;
//flag for saving data
bool shouldSaveConfig = false;
//callback notifying us of the need to save config
void saveConfigCallback () {
Serial.println("Should save config");
shouldSaveConfig = true;
void tick()
//toggle state
int state = digitalRead(BUILTIN_LED); // get the current state of GPIO1 pin
digitalWrite(BUILTIN_LED, !state); // set pin to the opposite state
int getRSSIasQuality(int RSSI) {
int quality = 0;
if (RSSI <= -100) {
quality = 0;
} else if (RSSI >= -50) {
quality = 100;
} else {
quality = 2 * (RSSI + 100);
return quality;
//gets called when WiFiManager enters configuration mode
void configModeCallback (WiFiManager *myWiFiManager) {
Serial.println("Entered config mode");
Serial.println(WiFi.softAPIP());
//if you used auto generated SSID, print it
Serial.println(myWiFiManager->getConfigPortalSSID());
//entered config mode, make led toggle faster
ticker.attach(1.2, tick);
#define DEVICECODE 1
#define VERSION 1
float convertC2F(float value)
return (value * 9.0) / 5.0 + 32.0; // Convert Celcius to Fahrenheit
Show how to read IR and Full Spectrum at once and convert to lux
void advancedRead(void)
// More advanced data read example. Read 32 bits with top 16 bits IR, bottom 16 bits full spectrum
// That way you can do whatever math and comparisons you want!
uint32_t lum = tsl.getFullLuminosity();
uint16_t ir, full;
float lux;
ir = lum >> 16;
full = lum & 0xFFFF;
lux = tsl.calculateLux(full, ir);
Serial.print("[ "); Serial.print(millis()); Serial.print(" ms ] ");
Serial.print("IR: "); Serial.print(ir); Serial.print(" ");
Serial.print("Full: "); Serial.print(full); Serial.print(" ");
Serial.print("Visible: "); Serial.print(full - ir); Serial.print(" ");
Serial.print("Lux: "); Serial.println(lux);
Configures the gain and integration time for the TSL2591
void configureSensor(void)
// You can change the gain on the fly, to adapt to brighter/dimmer light situations
//tsl.setGain(TSL2591_GAIN_LOW); // 1x gain (bright light)
tsl.setGain(TSL2591_GAIN_MED); // 25x gain
// tsl.setGain(TSL2591_GAIN_HIGH); // 428x gain
// Changing the integration time gives you a longer time over which to sense light
// longer timelines are slower, but are good in very low light situtations!
tsl.setTiming(TSL2591_INTEGRATIONTIME_100MS); // shortest integration time (bright light)
// tsl.setTiming(TSL2591_INTEGRATIONTIME_200MS);
// tsl.setTiming(TSL2591_INTEGRATIONTIME_300MS);
// tsl.setTiming(TSL2591_INTEGRATIONTIME_400MS);
// tsl.setTiming(TSL2591_INTEGRATIONTIME_500MS);
// tsl.setTiming(TSL2591_INTEGRATIONTIME_600MS); // longest integration time (dim light)
/* Display the gain and integration time for reference sake */
Serial.println("------------------------------------");
Serial.print ("Gain: ");
tsl2591Gain_t gain = tsl.getGain();
switch (gain)
case TSL2591_GAIN_LOW:
Serial.println("1x (Low)");
break;
case TSL2591_GAIN_MED:
Serial.println("25x (Medium)");
break;
case TSL2591_GAIN_HIGH:
Serial.println("428x (High)");
break;
case TSL2591_GAIN_MAX:
Serial.println("9876x (Max)");
break;
Serial.print ("Timing: ");
Serial.print((tsl.getTiming() + 1) * 100, DEC);
Serial.println(" ms");
Serial.println("");
int delayLen = 20000;
String MAC;
String SN;
char blynk_token[34] = "YOUR_BLYNK_TOKEN";
long sendTimer = millis();
float altitude = -999;
unsigned long IAQ_last = 0;
//String postData;
boolean s1Last = 1;
boolean s2Last = 1;
boolean s3Last = 1;
boolean s4Last = 1;
boolean s1 = 0;
boolean s2 = 0;
boolean s3 = 0;
boolean s4 = 0;
long s1db = 0;
long s2db = 0;
long s3db = 0;
long s4db = 0;
Wire.begin();
Wire.setClock(100000); //Set clock speed to 100KHz for stability
Serial.println("I live...");
// Serial.print(F("Connecting to "));
// Serial.println(WLAN_SSID);
// unsigned long wifiTimeout = millis();
// WiFi.begin(WLAN_SSID, WLAN_PASS);
//set led pin as output
pinMode(BUILTIN_LED, OUTPUT);
mcp.begin(); // use default address 0
mcp.pinMode(0, INPUT);
mcp.pullUp(0, HIGH); // turn on a 100K pullup internally
mcp.pinMode(1, INPUT);
mcp.pullUp(1, HIGH); // turn on a 100K pullup internally
mcp.pinMode(2, INPUT);
mcp.pullUp(2, HIGH); // turn on a 100K pullup internally
mcp.pinMode(3, INPUT);
mcp.pullUp(3, HIGH); // turn on a 100K pullup internally
Serial.println("Starting TSL2591...!");
if (tsl.begin())
Serial.println("Found a TSL2591 sensor");
/* Configure the sensor */
configureSensor();
advancedRead();
} else
Serial.println("No TSL2591 sensor found");
myPressure.begin(); // Get sensor online
//Configure the sensor
myPressure.setModeAltimeter(); // Measure altitude above sea level in meters
myPressure.setOversampleRate(64); // Set Oversample to the recommended 128
myPressure.enableEventFlags(); // Enable all three pressure and temp event flags
delay(2000);
unsigned long start = millis();
while ((altitude <= 0 | altitude > 9000) & millis() - start < 10000) {
altitude = myPressure.readAltitude();
yield();
if (altitude <= 0 | altitude > 9000) Serial.println("Crap - baro timed out :/");
myPressure.setModeBarometer(); // Measure pressure in Pascals from 20 to 110 kPa
WiFiManager wifiManager;
MAC = WiFi.macAddress();
Serial.println(MAC);
MAC.replace(":", "");
SN = MAC + ESP.getChipId();
//reset settings - for testing
//wifiManager.resetSettings();
wifiManager.bDisableIPhonePortal = true;
//set callback that gets called when connecting to previous WiFi fails, and enters Access Point mode
wifiManager.setAPCallback(configModeCallback);
// window.setTimeout(function(){ window.location = "http://www.yoururl.com"; },3000);
String tempURL = "<script>window.setTimeout(function(){ window.location = \"" + redirectURL + SN + "\"; }," + redirectTimeout + ");</script>";
wifiManager.setRedirectElement(tempURL);
WiFiManagerParameter custom_text("<p>Please choose the access point that you want to connect to above, then enter the password.</p><p>Paste your token into the field below.</p>");
wifiManager.addParameter(&custom_text);
//set config save notify callback
wifiManager.setSaveConfigCallback(saveConfigCallback);
WiFiManagerParameter custom_blynk_token("blynk", "blynk token", blynk_token, 32);
wifiManager.addParameter(&custom_blynk_token);
//fetches ssid and pass and tries to connect
//if it does not connect it starts an access point with the specified name
//here "AutoConnectAP"
//and goes into a blocking loop awaiting configuration
if (!wifiManager.autoConnect()) {
// start ticker with 0.5 because we start in AP mode and try to connect
ticker.attach(0.6, tick);
Serial.println("failed to connect and hit timeout");
//reset and try again, or maybe put it to deep sleep
ESP.reset();
delay(1000);
Serial.println("WiFi is connected.");
Serial.println("attempting HTTP update...");
t_httpUpdate_return ret = ESPhttpUpdate.update("http://u.synaptrix.com/spooky.bin");
//t_httpUpdate_return ret = ESPhttpUpdate.update("https://server/file.bin");
switch(ret) {
case HTTP_UPDATE_FAILED:
Serial.printf("HTTP_UPDATE_FAILED Error (%d): %s", ESPhttpUpdate.getLastError(), ESPhttpUpdate.getLastErrorString().c_str());
break;
case HTTP_UPDATE_NO_UPDATES:
Serial.println("HTTP_UPDATE_NO_UPDATES");
break;
case HTTP_UPDATE_OK:
Serial.println("HTTP_UPDATE_OK");
break;
digitalWrite(BUILTIN_LED, HIGH);
ticker.detach();
strcpy(blynk_token, custom_blynk_token.getValue());
Serial.println(blynk_token);
//Initialize switches
s1Last = mcp.digitalRead(0); Serial.print("Initializing Switch1. Status: "); Serial.println(s1Last);
s2Last = mcp.digitalRead(1); Serial.print("Initializing Switch2. Status: "); Serial.println(s2Last);
s3Last = mcp.digitalRead(2); Serial.print("Initializing Switch3. Status: "); Serial.println(s3Last);
s4Last = mcp.digitalRead(3); Serial.print("Initializing Switch4. Status: "); Serial.println(s4Last);
// while (WiFi.status() != WL_CONNECTED) {
// delay(500);
// Serial.print(F("."));
// if ((millis() - wifiTimeout) >= 10000 && BYPASSWIFITIMEOUT == 0) {
// break;
// if (WiFi.status() == WL_CONNECTED) {
// Serial.println();
// Serial.println(F("WiFi connected"));
// Serial.println(F("IP address: "));
// Serial.println(WiFi.localIP());
// } else {
// Serial.println(F("WiFi NOT connected"));
myPressure.readPressure();
boolean s1c = 0;
boolean s2c = 0;
boolean s3c = 0;
boolean s4c = 0;
long dbdelay = 100;
boolean gpio0 = 0;
boolean gpio0last =0 ;
// Check for reset
gpio0 = digitalRead(0);
if (gpio0 != gpio0last){
boolean sendNow = 0;
String postData = "sn=" + String(SN) + "&dc=" + String(DEVICECODE) + "&v=" + String(VERSION);
s1 = mcp.digitalRead(0);
if (s1 != s1Last) {
if (s1c == 0) {
s1db = millis();
s1c = 1;
} else if (millis() >= s1db + dbdelay) {
postData += "&s1=" + String(s1);
//change has occurred...
Serial.print("Switch1 has changed states. New value: "); Serial.println(s1);
sendNow = 1;
s1Last = s1;
s1c = 0;
s2 = mcp.digitalRead(1);
if (s2 != s2Last) {
if (s2c == 0) {
s2db = millis();
s2c = 1;
} else if (millis() >= s2db + dbdelay) {
postData += "&s2=" + String(s2);
Serial.print("Switch2 has changed states. New value: "); Serial.println(s2);
sendNow = 1;
s2Last = s2;
s2c = 0;
s3 = mcp.digitalRead(2);
if (s3 != s3Last) {
if (s3c == 0) {
s3db = millis();
s3c = 1;
} else if (millis() >= s3db + dbdelay) {
postData += "&s3=" + String(s3);
Serial.print("Switch3 has changed states. New value: "); Serial.println(s3);
sendNow = 1;
s3Last = s3;
s3c = 0;
s4 = mcp.digitalRead(3);
if (s4 != s4Last) {
if (s4c == 0) {
s4db = millis();
s4c = 1;
} else if (millis() >= s4db + dbdelay) {
postData += "&s4=" + String(s4);
Serial.print("Switch4 has changed states. New value: "); Serial.println(s4);
sendNow = 1;
s4Last = s4;
s4c = 0;
// s2 = mcp.digitalRead(1); Serial.print("Initializing Switch2. Status: "); Serial.print(s2Init);
// s3 = mcp.digitalRead(2); Serial.print("Initializing Switch3. Status: "); Serial.print(s3Init);
// s4 = mcp.digitalRead(3); Serial.print("Initializing Switch4. Status: "); Serial.print(s4Init);
if (millis() >= sendTimer + delayLen) {
// Serial.print(postData); Serial.print(" -- ");
// Serial.print(millis()); Serial.print(" -- "); Serial.print(delayLen); Serial.print(" -- "); Serial.println(sendTimer);
// Serial.println("sendtimer fired");
Serial.print("SHT20 here --> ");
SHT21.readSensor();
Serial.print("Humidity(%RH): ");
Serial.print(SHT21.humi, 1);
Serial.print(" Temperature(C/F): ");
Serial.print(SHT21.temp, 1); Serial.print("/");
Serial.println(convertC2F(SHT21.temp));
// 9/5 *C + 32
postData += "&t=" + String(convertC2F(SHT21.temp)) + "&h=" + String(SHT21.humi);
Serial.print("IAQ-Core here --> ");
unsigned long IAQCheck = read_IAQ(); // read iAQ-core
Serial.print(" == "); Serial.print(IAQ_last); Serial.print("/"); Serial.print(IAQCheck); Serial.print(" == ");
IAQ_last = IAQCheck;
postData += "&iaq=" + String(IAQCheck);
Serial.print("MPL here --> ");
Serial.print("Altitude(M/ft):");
Serial.print(altitude, 2);
Serial.print("/");
Serial.print(altitude * 3.28084, 2);
postData += "&alt=" + String(altitude * 3.28084);
float pressure = myPressure.readPressure();
Serial.print(" Pressure(Pa):");
Serial.print(pressure, 2);
postData += "&prs=" + String(pressure);
float temperature = myPressure.readTemp();
Serial.print(" Temp(C):");
Serial.print(temperature, 2);
postData += "&t2=" + String(convertC2F(temperature));
//References:
//Definition of "altimeter setting": http://www.crh.noaa.gov/bou/awebphp/definitions_pressure.php
//Altimeter setting: http://www.srh.noaa.gov/epz/?n=wxcalc_altimetersetting
//Altimeter setting: http://www.srh.noaa.gov/images/epz/wxcalc/altimeterSetting.pdf
//Verified against Boulder, CO readings: http://www.crh.noaa.gov/bou/include/webpres.php?product=webpres.txt
//const int station_elevation_ft = 5374; //Must be obtained with a GPS unit
float station_elevation_m = altitude * 0.3048; //I'm going to hard code this
//const int station_elevation_m = 140; //Accurate for the roof on my house
//1 pascal = 0.01 millibars
pressure /= 100; //pressure is now in millibars
float part1 = pressure - 0.3; //Part 1 of formula
const float part2 = 8.42288 / 100000.0;
float part3 = pow((pressure - 0.3), 0.190284);
float part4 = (float)station_elevation_m / part3;
float part5 = (1.0 + (part2 * part4));
float part6 = pow(part5, (1.0 / 0.190284));
float altimeter_setting_pressure_mb = part1 * part6; //Output is now in adjusted millibars
float baroin = altimeter_setting_pressure_mb * 0.02953;
Serial.print(" Altimeter setting InHg:");
Serial.print(baroin, 2);
postData += "&baro=" + String(baroin);
uint16_t ir, full;
int lux;
ir = lum >> 16;
Serial.print("TSL2591 here --> ");
postData += "&ir=" + String(ir) + "&full=" + String(full) + "&vis=" + String(full - ir) + "&lux=" + String(lux);
postData += "&vx=" + String(analogRead(A0));
sendNow = 1;
// delay(delayLen);
if (sendNow) {
String URL = dataURL + postData;
Serial.print(getRSSIasQuality(WiFi.RSSI())); Serial.print("% --> "); Serial.println(URL);
// int quality = getRSSIasQuality(WiFi.RSSI(indices[i]))
http.begin(URL);
// http.addHeader("Content-Type", "application/x-www-form-urlencoded");
// http.POST(postData);
http.GET();
String response = http.getString();
response.trim();
int result = response.toInt();
http.writeToStream(&Serial);
http.end();
Serial.print("==="); Serial.print(result); Serial.print("===");
delayLen = (result !=0 ) ? result * 1000 : 10000;
sendNow = 0;
postData = "";
