Found this online, where someone had a similar issue.
byte unsignedByte( int val ) { return (byte)( val > 127 ? val - 256 : val ); }
Might give it a go and see if that fixes the issue.
Explore... Chat... Share...
martinayotte wrote:Could be on the Putty side, but not on ESP side otherwise my python script would have shown the issue.
I'm not using Putty, but how the capture is been done ?
What is interesting is the fact that the capture shows 2 bytes for each one received.
DAFlippers wrote:Also note that you are not seeing 00 either. Your sequence is going 7F C280 ... C2BF C380... C3BF which is strange.
David
