By pidloop
#61036 Hello! I'm trying to connect to https://sdo.gsfc.nasa.gov using HTTPClient class. No luck so far, I always get connection refused. I've double checked the fingerprint (using google chrome's cert details feature). No problem connecting to other https sites such as wired.com. Can anyway figure out what's special about this site? Below is a sample sketch I'm using to explore this issue followed by the sketch output.
Also, once I get this working, I have a few more questions please:
1. It looks like HTTPClient.GET() stores the whole page into RAM. This will be a problem for me. Is there any way to read the page char-by-char? As you can see in my sample sketch, I've tried using HTTPClient.getStream() but based on the heap sizes it seems it still stores the whole page on the heap under the hood.
2. If I"m willing to accept the chance of being spoofed, is there any way to connect to an https site without needing to deal with the fingerprint stuff?
Many thanks for any help.
Elwood Downey
Tuscon Arizona
Code: Select all#include <Arduino.h>
#include <SPI.h>
#include <WiFiClient.h>
static char ssid[] = "clearskyinstitute";       // your network SSID (name)
static char pass[] = "from651plan";             // your network password
    Serial.begin (115200);
    Serial.print ("heap 1: "); Serial.println (ESP.getFreeHeap());
    if (WiFi.status() == WL_NO_SHIELD) {
        Serial.println("no shield");
        while (1)
           ESP.wdtFeed();
    // we only want station mode, not access too
    WiFi.mode(WIFI_STA);
    Serial.println ("connecting to WiFi");
    WiFi.begin (ssid, pass);                            // non-blocking, poll with status()
    uint32_t t0 = millis();
    uint32_t timeout = 15000UL;
        ESP.wdtFeed();
        if (millis() > t0 + timeout) {
             Serial.println ("no wifi");
             while(1);
                  ESP.wdtFeed();
        delay(1000);
    Serial.print ("heap 2: "); Serial.println (ESP.getFreeHeap());
    Serial.println ("trying connection");
    HTTPClient sdo_http;
    ESP.wdtFeed();
    if (!sdo_http.begin ("https://sdo.gsfc.nasa.gov/assets/img/latest/f_211_193_171_170.jpg",
                "8D 6B 9B BD AC E4 55 A8 D1 CA 54 67 6F 22 FE 9D 1A F1 2E 70")) {
    // if (!sdo_http.begin ("https://www.wired.com/index.html",
                   // "E8 BC F9 5F 59 AB 96 13 00 3D 0E 59 46 6C 6B 5E 7A AA 12 82")) {
        Serial.println ("begin fails");
        while (1)
            ESP.wdtFeed();
    Serial.print ("heap 3: "); Serial.println (ESP.getFreeHeap());
    int get_status = sdo_http.GET();
    ESP.wdtFeed();
    if (get_status < 0) {
        Serial.print ("GET: "); Serial.println (sdo_http.errorToString(get_status));
        while (1)
          ESP.wdtFeed();
    Serial.print ("heap 4: "); Serial.println (ESP.getFreeHeap());
    WiFiClient sdo_client = sdo_http.getStream();
    while (sdo_client.connected()) {
        while (!sdo_client.available())
          ESP.wdtFeed();
        (void) sdo_client.read();
        // Serial.print(sdo_client.read());
    Serial.print ("heap 5: "); Serial.println (ESP.getFreeHeap());
    sdo_client.stop();
    Serial.print ("heap 6: "); Serial.println (ESP.getFreeHeap());
    sdo_http.end();
    yield();
    Serial.print ("heap 7: "); Serial.println (ESP.getFreeHeap());
    Serial.print ("heap: "); Serial.println (ESP.getFreeHeap());
    for (uint8_t i = 0; i < 10; i++) {
        delay(1000);
        ESP.wdtFeed();
Output:
heap 1: 41216
connecting to WiFi
heap 2: 40984
trying connection
heap 3: 40680
GET: connection refused
