By _mf
#70030 Hi guys!
I'm having problems with connecting between two ESP's when one of them is in softAP mode. When they are both connected to a WiFi router, everything works, but when one of them is in softAP mode, connection fails 100% of the time. Everything works when I'm using a PC as either a TCP server or a TCP client, so the code must be correct.
I have tried different configurations and none of them work:
- ESP(STA + TCP CLIENT) to ESP(AP + TCP SERVER)
- ESP(AP + TCP CLIENT) to ESP(STA + TCP SERVER)
- ESP(STA + TCP CLIENT) through ESP(AP) to ESP(STA + TCP) server
Client:
Code: Select all#include <Arduino.h>
String ssid = "AAAAAAAA";
String pass = "AAAAAAAA";
WiFiClient client;
  WiFi.disconnect(true);
  WiFi.softAPdisconnect(true);
  ESP.eraseConfig();
  WiFi.mode(WIFI_AP_STA);
  WiFi.begin(ssid.c_str(), pass.c_str());
  while (WiFi.waitForConnectResult() != WL_CONNECTED) {
  delay(2000);
  IPAddress ip(192, 168, 4, 1);
  if (client.connect(ip, SRV_PORT)) {
    Serial.printf("Success!\n");
  } else {
    Serial.printf("Fail!\n");
  yield();
Server:
#define SRV_PORT 4210
#define SRV_MAX_CLIENTS 3
WiFiServer server(SRV_PORT);
WiFiClient serverClients[SRV_MAX_CLIENTS];
  ESP.eraseConfig();
  WiFi.softAP(ssid.c_str(), pass.c_str());
  delay(2000);
  server.begin();
  server.setNoDelay(true);
  yield();
  uint8_t i;
  if (server.hasClient()) {
    for (i = 0; i < SRV_MAX_CLIENTS; i++) {
      if (!serverClients[i] || !isConnected(&serverClients[i])) {
        if(serverClients[i]) serverClients[i].stop();
        serverClients[i] = server.available();
        serverClients[i].flush();
        continue;
    //no free spot
    WiFiClient serverClient = server.available();
    serverClient.stop();
    if (serverClients[i] && isConnected(&serverClients[i])) {
      Serial.prinf("Got data!\n");
bool isConnected(WiFiClient* c) {
  return c->connected() && c->status() != 0;
I've spent a whole day debugging and trying to fix this, but can't find a solution. I've analyzed the TCP protocol through Wireshark on a PC when the PC was the TCP server and the ESP was the TCP client and the other way around and everything seems to be OK.
Please help!
