When I run the code I perfectly works for 1 time then I get this error : 0⸮~⸮4⸮
I found zero answers online when typing this error. Not something even close to a solution.
So I turned here in hope of founding a solution.
Explore... Chat... Share...
2.Cleverly put the Thing to sleep.
The best choice is the second option.Before using the deepsleep feature, Wemos D0 pin must be connected to the Reset pin.
