By Athmesh Nandakumar
#90927 Hi,
I'm using esp8266. I'm using MQTT library and trying to post some data every 10 seconds to a topic.
I was able to connect and post data to the topic. But i get some unwanted characters(garbage) in the mqtt window.
Procedure:
I am using a serial tx from arm controller to the esp rx so when i get the data, i send it over the mqtt server from esp.
Problem:
I tried debugging the arm core, i am sending the exact data from controller via the memory window of the controller. But at the mqtt window, i'm getting some junk values.
