By Buffalochill
#62352 hello guys!
I have set up a ESP as a TCP server (which also hosts the WiFi) and one as a TCP client.
somehow the performance is too slow. I only get one request and response per second.
could you have a look at my code please?
Server code:
Code: Select all//-- Libraries Included --------------------------------------------------------------
  // Define I/O Pins
  #define     LED0        2         // WIFI Module LED
  #define     analogPin   A0        // ADC pin lichtorgel
  // Authentication Variables
  char*       ssid;              // SERVER WIFI NAME
  char*       password;          // SERVER PASSWORD
  #define     MAXSC     6           // MAXIMUM NUMBER OF CLIENTS
  WiFiServer  TCP_SERVER(9001);      // THE SERVER AND THE PORT NUMBER
  WiFiClient  TCP_Client[MAXSC];     // THE SERVER CLIENTS Maximum number
  void setup()
    // Setting The Serial Port
    Serial.begin(115200);           // Computer Communication
    // Setting The Mode Of Pins
    pinMode(LED0, OUTPUT);          // WIFI OnBoard LED Light
    pinMode(analogPin, INPUT);      // ADC PIN
    // Setting Up A Wifi Access Point
    SetWifi("TCP_SERVER","");
  void loop()
    HandleClients();
  void SetWifi(char* Name, char* Password)
    // Stop Any Previous WIFI
    WiFi.disconnect();
    // Setting The Wifi Mode
    WiFi.mode(WIFI_AP_STA);
    Serial.println("WIFI Mode : AccessPoint Station");
    // Setting The AccessPoint Name & Password
    ssid      = Name;
    password  = Password;
    // Starting The Access Point
    WiFi.softAP(ssid, password);
    Serial.println("WIFI < " + String(ssid) + " > ... Started");
    // Wait For Few Seconds
    delay(1000);
    // Getting Server IP
    IPAddress IP = WiFi.softAPIP();
    // Printing The Server IP Address
    Serial.print("AccessPoint IP : ");
    Serial.println(IP);
    // Starting Server
    TCP_SERVER.begin();
    Serial.println("Server Started");
  void HandleClients()
    if(TCP_SERVER.hasClient())
       WiFiClient Client = TCP_SERVER.available();
       while(1)
        // If Clients Are Connected
        if(Client.available())
          // Here We Read The Message
          String Message = Client.readStringUntil('\r');
          // Here We Print The Message On The Screen
          Serial.println(Message);
          // Here We Reply To The Client With A Message
          Client.print("Here is my Response!");
          Client.flush();
        // If Clients Are Disconnected
       /* if(!TCP_Client || !TCP_Client.connected())
          // Here We Turn Off The LED To Indicated The Its Disconnectted
          //digitalWrite(LED1, LOW);
          // Here We Jump Out Of The While Loop
          break;
  // This LED Blinks If No Clients Where Available
  digitalWrite(LED0, HIGH);
  delay(250);
  digitalWrite(LED0, LOW);
  delay(250);
and here the Client code:
Code: Select all//------------------------------------------------------------------------------------
// Libraries Needed For This Project
  #include <Wire.h>           // To Be Able To Use Sensors Like IMU9050
  #include <EEPROM.h>         // To Be Able To Store & Read Data Between Power Off
  #include <ESP8266WiFi.h>    // The Basic Function Of The ESP NOD MCU
// Defining I/O Pins
  const String  Devicename        = "Rainbow1";
// WIFI Authentication Variables
/* This Client Is Going To Connect To A WIFI Server Access Point
 * So You Have To Specify Server WIFI SSID & Password In The Code Not Here
 * Please See The Function Below Name (WiFi.Begin)
 * If WIFI dont need Any password Then WiFi.begin("SSIDNAME")
 * If WIFI needs a Password Then WiFi.begin("SSIDNAME", "PASSWORD")
  char*         ssid;            // Wifi Name
  char*         password;        // Wifi Password
// WIFI Module Role & Port
/* This WIFI Module Code Works As A Client
 * That Will Connect To A Server WIFI Modul With (IP ADDress 192.168.4.1)
  int             TCP_ServerPort  = 9001;
  IPAddress       TCP_Server(192,168,4,1);
  WiFiClient      TCP_Client;
  void setup()
    // Setting The Serial Port ----------------------------------------------
    // Setting The Mode Of Pins ---------------------------------------------
    digitalWrite(LED0, !LOW);       // Turn WiFi LED Off
    // Print Message Of I/O Setting Progress --------------------------------
    Serial.println("\nI/O Pins Modes Set .... Done");
    // WiFi Connect ----------------------------------------------------
    Check_WiFi_and_Connect_or_Reconnect();        // Checking For Connection
  void loop()
    Send_Request_To_Server();
  void Send_Request_To_Server() {
       TCP_Client.println("Here my message!");
       if(TCP_Client.available()) {
      String Response = TCP_Client.readStringUntil('\r');
       Serial.println(Response);
       TCP_Client.flush();  // Bufffer löschen
  void Check_WiFi_and_Connect_or_Reconnect()
    if (WiFi.status() != WL_CONNECTED){
    TCP_Client.stop();  //Erstmal sicher gehen dass alles resettet wurde
    WiFi.disconnect();
    Serial.println("Not Connected...trying to connect...");
    //Serial.println("!--- Connecting To " + WiFi.SSID() + " ---!");
    delay(5000);
    WiFi.mode(WIFI_STA);               // To Avoid Broadcasting An SSID
    WiFi.begin("TCP_SERVER");          // The SSID That We Want To Connect To
    while(WiFi.status() != WL_CONNECTED)
      for(int i=0; i < 10; i++)
        digitalWrite(LED0, !HIGH);
        delay(250);
        delay(250);
        Serial.print(".");
      Serial.println("");
    // Stop Blinking To Indicate Connected ----------------------------------
    Serial.println("!-- Client Device Connected --!");
    // Printing IP Address --------------------------------------------------
    Serial.println("Connected To      : " + String(WiFi.SSID()));
    Serial.println("Signal Strenght   : " + String(WiFi.RSSI()) + " dBm");
    Serial.print  ("Server IP Address : ");
    Serial.println(TCP_Server);
    Serial.print  ("Device IP Address : ");
    // Conecting The Device As A Client -------------------------------------
    Tell_Server_we_are_there();
  void I2C_Begin()
     * Setting The I2C Pins SDA, SCL
     * Because We Didnt Specify Any Pins The Defult
     * SDA = D4 <GPIO2>, SCL = D5 <GPIO14> For ESP8266 Dev Kit Node MCU v3
    // Frequency Of The I2C
    #define TWI_FREQ  400000L       // I2C Frequency Setting To 400KHZ
    // If Ever You Needed To Use Wire I2C
    Wire.begin();                   // Begginning The I2C
    // Setting Up The I2C Of The MPU9250 ------------------------------------
    Wire.setClock(TWI_FREQ);        // Setting The Frequency MPU9250 Require
  void Tell_Server_we_are_there()
    // First Make Sure You Got Disconnected
    TCP_Client.stop();
    // If Sucessfully Connected Send Connection Message
    if(TCP_Client.connect(TCP_Server, TCP_ServerPort))
      Serial.println    ("<" + Devicename + "-CONNECTED>");
      TCP_Client.println ("<" + Devicename + "-CONNECTED>");
I also tried just to send data from the server towards the client (without request/response) ... in that case I had 3 packets per second, but that was still too poor.
I need packeds arround 100times, transmitted to 6 clients in a second for my project and i read that it should be possible.
Regards
Stefan
By rudy
#62377 I wasn't able to find your throughput problem though. I'm not a programmer.
Maximum number of clients, it is 5. https://github.com/esp8266/Arduino/issu ... -224143871
If you need more devices then maybe consider using UDP. It has no connections. Send and receive without verification of reception. But it is fast.
