By gbafamily1
#63478
Code: Select all/**
 * BasicHTTPClientPost.ino
 * See http://posttestserver.com/ for the HTTP server details.
#include <ESP8266WiFiMulti.h>
#define USE_SERIAL Serial
ESP8266WiFiMulti WiFiMulti;
    USE_SERIAL.begin(115200);
   // USE_SERIAL.setDebugOutput(true);
    USE_SERIAL.println();
    for(uint8_t t = 4; t > 0; t--) {
        USE_SERIAL.printf("[SETUP] WAIT %d...\n", t);
        USE_SERIAL.flush();
        delay(1000);
    WiFiMulti.addAP("SSID", "password");
    // wait for WiFi connection
    if((WiFiMulti.run() == WL_CONNECTED)) {
        HTTPClient http;
        USE_SERIAL.print("[HTTP] begin...\n");
        // Use posttestserver.com
        http.begin("http://posttestserver.com/post.php");
        http.addHeader("Content-Type", "application/x-www-form-urlencoded", false, true);
        USE_SERIAL.print("[HTTP] POST...\n");
        // start connection and send HTTP header
        int httpCode = http.POST("arg1=value1&arg2=value2");
        // httpCode will be negative on error
        if(httpCode > 0) {
            // HTTP header has been send and Server response header has been handled
            USE_SERIAL.printf("[HTTP] POST... code: %d\n", httpCode);
            // file found at server
            if(httpCode == HTTP_CODE_OK) {
                USE_SERIAL.println(payload);
        } else {
            USE_SERIAL.printf("[HTTP] POST... failed, error: %s\n", http.errorToString(httpCode).c_str());
        http.end();
    delay(10000);
