By claudiuchiru
#12906 simple example
#include <PubSubClient.h>
#include <DHT.h>
const char* ssid = "ssid";
const char* password = "password";
char* topic = "dht11";
char* server = "mqtt broker adress";
String clientName = "Arduino-esp";
#define DHTPIN 2 // what pin we're connected to
#define DHTTYPE DHT11 // DHT 11
DHT dht(DHTPIN, DHTTYPE,15);
WiFiClient wifiClient;
PubSubClient client(server, 1883, callback, wifiClient);
void callback(char* topic, byte* payload, unsigned int length) {
// handle message arrived
delay(10);
dht.begin();
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.print(server);
Serial.print(" as ");
Serial.println(clientName);
if (client.connect((char*) clientName.c_str())) {
Serial.println("Connected to MQTT broker");
Serial.print("Topic is: ");
Serial.println(topic);
else {
Serial.println("MQTT connect failed");
Serial.println("Will reset and try again...");
abort();
float h = dht.readHumidity();
float t = dht.readTemperature();
if (isnan(h) || isnan(t)) {
return;
static int counter = 0;
String payload ;
payload += t;
payload += ":";
payload += h;
if (client.connected()){
Serial.print("Sending payload: ");
Serial.println(payload);
if (client.publish(topic, (char*) payload.c_str()))
Serial.println("Publish ok");
else {
Serial.println("Publish failed");
else {
++counter;
delay(5000);
