By alextu
#36391 hi, it does start with ESP, but does not have a dash - in it
could you see about this in your serial debug:
> Also interesting would be to see what your serial debug says after line ""Configuring access point... ", it should give you the intended name of the AP
By julia freeman
#36408 1- I think am using the current stable version dated 30 Nov.
2- Alex, you are right: I changed the string "ESP" in the library to "ABC" but I still get ESP_something
3- In the debug window, the intended AP name is indeed "AutoConnectAP"
This means that the AP name is set somewhere else but again, I think am using the stable version.
I will reload it however to double check.
julia
