Re: *Solved* Using GET command to get data from ThingHTTP
Posted: Tue Sep 01, 2015 2:03 pm
Thank for your post. It was my big problem too-)
Open Community Forum for ESP8266, Come share Arduino and IoT (Internet of Things)
https://www.esp8266.com/
oeyhaga wrote:Seem I'v solved the problem. As easy as adding a longer delay after GET command.
Changed delay(10); to delay(500)
Finaly I can continue with the project after many hours scratching my headCode: Select all#include <ESP8266WiFi.h>
const char* ssid = "NAME";
const char* password = "PASSWORD";
const char* host = "api.thingspeak.com";
int value = 1;
delay(10);
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.println("");
}//end setup
delay(5000);
Serial.println(host);
WiFiClient Client;
const int httpPort = 80;
if (!Client.connect(host, httpPort)) {
Serial.println("Connection failed");
return;
// We now create a URI for the request
String url = "/apps/thinghttp/send_request?api_key=PAW43HX9QN9SVOW1";
Serial.print("Requesting URL: ");
Serial.println(host + url);
Serial.println(String("TRY: ") + value + ".");
Client.print(String("GET ") + url + "&headers=false" + " HTTP/1.1\r\n" + "Host: " + host + "\r\n" + "Connection: close\r\n\r\n");
while(Client.available()){
String line = Client.readStringUntil('\r');
Serial.println(line);
Serial.println("");
Serial.println(String("Try nr. ") + value + " is finished.");
Serial.println("Waiting for next try...");
Serial.println("");
value = value + 1;
delay(20000);
