By martinayotte
#25733 So, the previous bug simply disappeared with magic ? :o
You can add temporarily the following code inside the NTP/ntp.cpp around line 47 :
Code: Select allSerial.print("Unix time = ");
Serial.println(secsSince1970);
Next thing to do will be to have your LCD working ... ;)
By jimbob321
#25787 well the "no ntp response" happends when it goes for an update now..
i put those Serial prints in the cpp. and got no results.
i do have an 8 digit Hy-le8n led display but it's 5v.
By jimbob321
#25789 here is the cpp.
i dont know why the serial print does not work.i also changed the print on line 38 to received instead of receive but does not change the serial output still says receive..
Code: Select all/****************************************************************************
 *  NTP.cpp - gets current time from an NTP server or pool of servers.
 *      It is meant to be used with setSyncProvider from the Time library
 *       - see Example WifiClock
 *      This code is a modified version of the example "Time_NTP.pde" which
 *      is included with the time library.
 *      modified by William Moeur and made into a library: 28 MAY 2015.
 *      This code is in the public domain.
#include "ESP8266WiFi.h"
#include "Arduino.h"
#include "ntp.h"
NTP::NTP(void)
void NTP::begin(const char* ntpServerName, int TimeZoneOffset)
   _serverName = ntpServerName;
   _timeZoneOffset = TimeZoneOffset;
   /* Start WiFiUDP socket, listening at local port LOCALPORT */
   UDP.begin(LOCALPORT);
time_t NTP::getNtpTime(void)
  while (UDP.parsePacket() > 0) ; // discard any previously received packets
  //get a random server from the pool
  IPAddress timeServerIP;
  WiFi.hostByName(_serverName, timeServerIP);
  sendNTPpacket(timeServerIP);
  uint32_t beginWait = millis();
  while (millis() - beginWait < 1500) {
    int size = UDP.parsePacket();
    if (size >= NTP_PACKET_SIZE) {
      Serial.println("Received NTP Response");        //put d on receive
      UDP.read(packetBuffer, NTP_PACKET_SIZE);  // read packet into the buffer
      time_t secsSince1900;
      // convert four bytes starting at location 40 to a long integer
      secsSince1900 |=  (time_t)packetBuffer[40] << 24;
      secsSince1900 |= (time_t)packetBuffer[41] << 16;
      secsSince1900 |= (time_t)packetBuffer[42] << 8;
      secsSince1900 |= (time_t)packetBuffer[43];
      time_t secsSince1970 = secsSince1900 - 2208988800UL;
      int8_t totalOffset = (int8_t)(_timeZoneOffset + DSToffset(secsSince1970));
     Serial.print("Unix time = ");        //temp print
      Serial.println(secsSince1970);        //temp print
      return secsSince1970 + (time_t)(totalOffset * SECS_PER_HOUR) ;
    yield();
  Serial.println("No NTP Response :-(");
  return 0; // return 0 if unable to get the time
// send an NTP request to the time server at the given address
void NTP::sendNTPpacket(IPAddress &address)
  // set all bytes in the buffer to 0
  memset(packetBuffer, 0, NTP_PACKET_SIZE);
  // Initialize values needed to form NTP request
  // (see URL above for details on the packets)
  packetBuffer[0] = 0b11100011;   // LI, Version, Mode
  packetBuffer[1] = 0;     // Stratum, or type of clock
  packetBuffer[2] = 6;     // Polling Interval
  packetBuffer[3] = 0xEC;  // Peer Clock Precision
  // 8 bytes of zero for Root Delay & Root Dispersion
  packetBuffer[12]  = 49;
  packetBuffer[13]  = 0x4E;
  packetBuffer[14]  = 49;
  packetBuffer[15]  = 52;
  // all NTP fields have been given values, now
  // you can send a packet requesting a timestamp:
  UDP.beginPacket(address, 123); //NTP requests are to port 123
  UDP.write(packetBuffer, NTP_PACKET_SIZE);
  UDP.endPacket();
uint8_t NTP::DSToffset(time_t date)
  /*DST is between -
   * 2nd Sunday of March @2AM
   *        - and -
   * 1st Sunday of November @2AM
  //get seconds for 2nd Sunday of March
  tmElements_t tm;
  tm.Month = 3; //MARCH
  tm.Year = year(date) - 1970;
  tm.Day = 7; //March 7th
  time_t beginDST = nextSunday( makeTime(tm) ) + 2*SECS_PER_HOUR;
  //get seconds for 1st Sunday in November
  tm.Month = 10; //October
  tm.Day = 31; //last day of October;
  time_t endDST = nextSunday( makeTime(tm) ) + 2*SECS_PER_HOUR;
  //now, if we are between the two times we are in DST
  return (((date >= beginDST) && (date < endDST))? 1: 0);
By martinayotte
#25794 You must have done a mistake somehow, maybe you have 2 copies of the library, because if you get the "Received NTP Response" and don't get the "Unix time = " which are nearby of each other...
Look at the compile output, at the beginning, it shows the path of the libraries used during compile.
