By harald25
#48171 Alright!! I figured it out!
The problem was in the receiving end of the SLIP packets, on the Teensy.
I had 'if(!msgIN.hasError())' inside the loop: 'while(!SLIPSerial.endofPacket())'
What happened was that the OSC message was being filled up, and when the address of the message was filled in msgIN.hasError() no longer gave an error.
Therefore msgIN.route() invoked the function matching the OSC message address before any value was filled in to the message.
The solution was to move 'if(!msgIN.hasError())' outside of the while loop, and everything worked like a charm!
This code worked:
Code: Select allvoid OSCMsgReceive()
  OSCMessage msgIN;
  int size;
  static unsigned long microsTime = 0;
  while (!SLIPSerial.endofPacket())
    if ((size = SLIPSerial.available()) > 0)
      microsTime = micros();
      while (size--)  //this needs a byte limit
        msgIN.fill(SLIPSerial.read());
    if ((micros() - microsTime) > 10000) break; //Timeout for no eoP()
    //msgIN.route("/OnOff/toggle1",toggleOnOff);
    msgIN.route("/Fader/Value",funcValue);
    //msgIN.route("/XY/xy",xy);
The original code that did NOT work:
  OSCMessage msgIN;
  int size;
    if((size = SLIPSerial.available()) > 0)
      while(size--)
By jazzvivi
#85480
mogs wrote:Hello ESP8266 community.
I recently had need to forward OSC messages from TouchOSC http://hexler.net/software/touchosc to an Arduino (Teensy 3.1) based project. The ideal solution was of course to have esp8266 acting as a gateway to one of the available UARTs.
I found the CNMAT OSC library https://github.com/CNMAT/OSC but this didn't work correctly out of the box. After looking through this forum I found ameisso's port of the library https://github.com/ameisso/OSCLib-for-ESP8266 with which I was able to successfully receive and respond to messages from TouchOSC.
For some reason it does not include the SLIPEncodedSerial part of the CNMAT library. If you simply take SLIPEncodedSerial.cpp and SLIPEncodedSerial.h from CNMAT and put it into the ameisso library folder, serial OSC messages work as well.
After some initial issues with losing bytes while reading SLIP messages I was able to get the thing working. So far this implementation has proved to be pretty reliable (*EDIT* see note below about message flooding). I'm now enjoying building up control surfaces in TouchOSC for use on the Teensy3.1.
Some issues I am aware of:
    Serial->UDP messages are being truncated to approximately 500 bytes, this could cause issues with long messages/bundles.
    OSCBundles are not implemented, at this time I have not experimented with bundles at all.
    *EDIT* esp8266 module will crash if messages come in too quickly.
*EDIT* 2/9/2015: now rate limited to approx. 100 messages/second, excess messages are simply discarded. This seems more stable now. Ideally I would only discard duplicate messages, but this works well enough for my current needs.
Code: Select all// This program converts UDP OSC messages into SLIP Serial OSC messages on the ESP8266 wifi board
// At the moment there is no OSC bundle support, not sure I need it at the moment
#include <WiFiUDP.h>
#include <OSCMessage.h>
#include <SLIPEncodedSerial.h>
int status = WL_IDLE_STATUS;
const char* ssid = "wifissid";  //  your network name (SSID)
const char* pass = "wifipassword";       // your network password
int localPort = 8000;
int destPort = 9000;
IPAddress outIp(192, 168, 2, 39); //default IP, will change with received udp
WiFiUDP Udp;
SLIPEncodedSerial SLIPSerial(Serial);
void setup()
  SLIPSerial.begin(115200);
  WiFi.begin(ssid, pass);
  int tries=0;
    tries++;
    if (tries > 30){
      break;
  Udp.begin(localPort);
void loop(){ // read=udp->serial, write=serial->udp
  int rd,wr;
  OSCMessage rMsg, wMsg;
  //static unsigned int bp = 0;
  static bool packet = 0;
  static unsigned long  tr = 0, tw = 0;
  if((rd = Udp.parsePacket())>0){
    if(tr - micros() > 10000) {
      outIp = Udp.remoteIP();
      while (rd--)
        rMsg.fill(Udp.read());
      if(!rMsg.hasError()) {
        SLIPSerial.beginPacket();
        rMsg.send(SLIPSerial);
        SLIPSerial.endPacket();
      rMsg.empty();
    } else {
      while (rd--)
        Udp.read();
    tr = micros();
  while(!SLIPSerial.endofPacket()) {
    if(wr = SLIPSerial.available()>0){
      tw = micros();
      if(!packet)
        packet = 1;
      while(wr--) { //this needs a byte limit
        wMsg.fill(SLIPSerial.read());
        //if(++bp >= 512) break; //packets seem to get truncated about here anyway
    if((micros() - tw) > 10000) break; //Timeout for no eoP()
    //if(bp >= 512) break; //break again
  if(packet) {
    if(!wMsg.hasError()) {
      Udp.beginPacket(outIp, destPort);
      wMsg.send(Udp);
      Udp.endPacket();
      packet = 0;
Regards, mogs
[/url]
Hello, your code is very interesting, I am trying to combine it with a project I found to build some encoders, on a lighting table. The attached code works by serial USB communicating well but my console does not support USB osc by working with Windows XP. I need to send the data over wifi. Can you help me combine both codes?
https://community.etcconnect.com/etclab ... -lighthack
Code: Select all// Copyright (c) 2017 Electronic Theatre Controls, Inc., http://www.etcconnect.com
// Permission is hereby granted, free of charge, to any person obtaining a copy
// of this software and associated documentation files (the "Software"), to deal
// in the Software without restriction, including without limitation the rights
// to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
// copies of the Software, and to permit persons to whom the Software is
// furnished to do so, subject to the following conditions:
// The above copyright notice and this permission notice shall be included in
// all copies or substantial portions of the Software.
// THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
// IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
// FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
// AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
// LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
// OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
// THE SOFTWARE.
     lighthack - Box 1
     (C) 2017-2018 by ETC
     This code implements a Pan/Tilt module using two encoders and three
     buttons. The two encoders function as pan and tilt controllers with one
     button being reserved for controlling fine/coarse mode. The other two
     buttons are assigned to Next and Last which make it easy to switch between
     channels.
    NOTE: UPDATE VERSION_STRING IN DEFINITIONS BELOW WHEN VERSION NUMBER CHANGES
    Revision History
    yyyy-mm-dd   Vxx      By_Who                 Comment
    2017-07-21   1.0.0.1  Ethan Oswald Massey    Original creation
    2017-10-19   1.0.0.2  Sam Kearney            Fix build errors on some
                                                 Arduino platforms. Change
                                                 OSC subscribe parameters
    2017-10-24   1.0.0.3  Sam Kearney            Add ability to scale encoder
                                                 output
    2017-11-22   1.0.0.4  Hans Hinrichsen        Add splash msg before Eos
                                                 connects
    2017-12-07   1.0.0.5  Hans Hinrichsen        Added timeout to disconnect
                                                 and show splash screen again
    2018-10-25   2.0.0.0  Richard Thompson       Generalised to support other
                                                 ETC consoles
    2018-10-25   2.0.0.1  Richard Thompson       Add basic support for ColorSource
   Includes
#include <OSCBoards.h>
#include <OSCBundle.h>
#include <OSCData.h>
#include <OSCMatch.h>
#include <OSCTiming.h>
#ifdef BOARD_HAS_USB_SERIAL
#include <SLIPEncodedUSBSerial.h>
SLIPEncodedUSBSerial SLIPSerial(thisBoardsSerialUSB);
#else
#endif
#include <LiquidCrystal.h>
#include <string.h>
   Macros and Constants
#define LCD_CHARS           16
#define LCD_LINES           2   // Currently assume at least 2 lines
#define NEXT_BTN            6
#define LAST_BTN            7
#define SHIFT_BTN           8
#define SUBSCRIBE           ((int32_t)1)
#define UNSUBSCRIBE         ((int32_t)0)
#define EDGE_DOWN           ((int32_t)1)
#define EDGE_UP             ((int32_t)0)
#define FORWARD             0
#define REVERSE             1
// Change these values to switch which direction increase/decrease pan/tilt
#define PAN_DIR             FORWARD
#define TILT_DIR            FORWARD
// Use these values to make the encoder more coarse or fine.
// This controls the number of wheel "ticks" the device sends to the console
// for each tick of the encoder. 1 is the default and the most fine setting.
// Must be an integer.
#define PAN_SCALE           1
#define TILT_SCALE          1
#define SIG_DIGITS          3   // Number of significant digits displayed
#define OSC_BUF_MAX_SIZE    512
const String HANDSHAKE_QUERY = "ETCOSC?";
const String HANDSHAKE_REPLY = "OK";
//See displayScreen() below - limited to 10 chars (after 6 prefix chars)
#define VERSION_STRING      "2.0.0.1"
#define BOX_NAME_STRING     "box1"
// Change these values to alter how long we wait before sending an OSC ping
// to see if Eos is still there, and then finally how long before we
// disconnect and show the splash screen
// Values are in milliseconds
#define PING_AFTER_IDLE_INTERVAL    2500
#define TIMEOUT_AFTER_IDLE_INTERVAL 5000
   Local Types
enum WHEEL_TYPE { TILT, PAN };
enum WHEEL_MODE { COARSE, FINE };
struct Encoder
  uint8_t pinA;
  uint8_t pinB;
  int pinAPrevious;
  int pinBPrevious;
  float pos;
  uint8_t direction;
struct Encoder panWheel;
struct Encoder tiltWheel;
enum ConsoleType
  ConsoleNone,
  ConsoleEos,
  ConsoleCobalt,
  ConsoleColorSource
   Global Variables
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
bool updateDisplay = false;
ConsoleType connectedToConsole = ConsoleNone;
unsigned long lastMessageRxTime = 0;
bool timeoutPingSent = false;
   Local Functions
   Issues all our subscribes to Eos. When subscribed, Eos will keep us updated
   with the latest values for a given parameter.
   Parameters:  none
   Return Value: void
void issueEosSubscribes()
  // Add a filter so we don't get spammed with unwanted OSC messages from Eos
  OSCMessage filter("/eos/filter/add");
  filter.add("/eos/out/param/*");
  filter.add("/eos/out/ping");
  filter.send(SLIPSerial);
  // subscribe to Eos pan & tilt updates
  OSCMessage subPan("/eos/subscribe/param/pan");
  subPan.add(SUBSCRIBE);
  subPan.send(SLIPSerial);
  OSCMessage subTilt("/eos/subscribe/param/tilt");
  subTilt.add(SUBSCRIBE);
  subTilt.send(SLIPSerial);
   Given a valid OSCMessage (relevant to Pan/Tilt), we update our Encoder struct
   with the new position information.
   Parameters:
    msg - The OSC message we will use to update our internal data
    addressOffset - Unused (allows for multiple nested roots)
   Return Value: void
void parseFloatPanUpdate(OSCMessage& msg, int addressOffset)
  panWheel.pos = msg.getOSCData(0)->getFloat();
  updateDisplay = true;
void parseFloatTiltUpdate(OSCMessage& msg, int addressOffset)
  tiltWheel.pos = msg.getOSCData(0)->getFloat();
void parseEos(OSCMessage& msg, int addressOffset)
  // If we don't think we're connected, reconnect and subscribe
  if (connectedToConsole != ConsoleEos)
    issueEosSubscribes();
    connectedToConsole = ConsoleEos;
  if (!msg.route("/out/param/pan", parseFloatPanUpdate, addressOffset))
    msg.route("/out/param/tilt", parseFloatTiltUpdate, addressOffset);
void parseCobalt(OSCMessage& msg, int addressOffset)
  // Cobalt doesn't currently send anything other than ping
  connectedToConsole = ConsoleCobalt;
void parseColorSource(OSCMessage& msg, int addressOffset)
  // ColorSource doesn't currently send anything other than ping
  connectedToConsole = ConsoleColorSource;
   Given an unknown OSC message we check to see if it's a handshake message.
   If it's a handshake we issue a subscribe, otherwise we begin route the OSC
   message to the appropriate function.
   Parameters:
    msg - The OSC message of unknown importance
   Return Value: void
void parseOSCMessage(String& msg)
  // check to see if this is the handshake string
  if (msg.indexOf(HANDSHAKE_QUERY) != -1)
    // handshake string found!
    SLIPSerial.write((const uint8_t*)HANDSHAKE_REPLY.c_str(), (size_t)HANDSHAKE_REPLY.length());
    // An Eos would do nothing until subscribed
    // Let Eos know we want updates on some things
  else
    // prepare the message for routing by filling an OSCMessage object with our message string
    OSCMessage oscmsg;
    oscmsg.fill((uint8_t*)msg.c_str(), (int)msg.length());
    // route pan/tilt messages to the relevant update function
    // Try the various OSC routes
    if (oscmsg.route("/eos", parseEos))
      return;
    if (oscmsg.route("/cobalt", parseCobalt))
      return;
    if (oscmsg.route("/cs", parseColorSource))
      return;
   Updates the display with the latest pan and tilt positions.
   Parameters:  none
   Return Value: void
void displayStatus()
  lcd.clear();
  switch (connectedToConsole)
    case ConsoleNone:
        // display a splash message before the Eos connection is open
        lcd.setCursor(0, 0);
        lcd.print(BOX_NAME_STRING " v" VERSION_STRING);
        lcd.setCursor(0, 1);
        lcd.print("Waiting...");
      } break;
    case ConsoleEos:
        // put the cursor at the begining of the first line
        lcd.print("Pan:  ");
        lcd.print(panWheel.pos, SIG_DIGITS);
        // put the cursor at the begining of the second line
        lcd.print("Tilt: ");
        lcd.print(tiltWheel.pos, SIG_DIGITS);
      } break;
    case ConsoleCobalt:
        lcd.setCursor(7, 0);
        lcd.print("Cobalt");
        lcd.print("Pan");
        lcd.setCursor(12, 1);
        lcd.print("Tilt");
      } break;
    case ConsoleColorSource:
        lcd.setCursor(2, 0);
        lcd.print("ColorSource");
        lcd.print("Pan");
        lcd.print("Tilt");
      } break;
   Initializes a given encoder struct to the requested parameters.
   Parameters:
    encoder - Pointer to the encoder we will be initializing
    pinA - Where the A pin is connected to the Arduino
    pinB - Where the B pin is connected to the Arduino
    direction - Determines if clockwise or counterclockwise is "forward"
   Return Value: void
void initEncoder(struct Encoder* encoder, uint8_t pinA, uint8_t pinB, uint8_t direction)
  encoder->pinA = pinA;
  encoder->pinB = pinB;
  encoder->pos = 0;
  encoder->direction = direction;
  pinMode(pinA, INPUT_PULLUP);
  pinMode(pinB, INPUT_PULLUP);
  encoder->pinAPrevious = digitalRead(pinA);
  encoder->pinBPrevious = digitalRead(pinB);
   Checks if the encoder has moved by comparing the previous state of the pins
   with the current state. If they are different, we know there is movement.
   In the event of movement we update the current state of our pins.
   Parameters:
    encoder - Pointer to the encoder we will be checking for motion
   Return Value:
    encoderMotion - Returns the 0 if the encoder has not moved
                                1 for forward motion
                               -1 for reverse motion
int8_t updateEncoder(struct Encoder* encoder)
  int8_t encoderMotion = 0;
  int pinACurrent = digitalRead(encoder->pinA);
  int pinBCurrent = digitalRead(encoder->pinB);
  // has the encoder moved at all?
  if (encoder->pinAPrevious != pinACurrent)
    // Since it has moved, we must determine if the encoder has moved forwards or backwards
    encoderMotion = (encoder->pinAPrevious == encoder->pinBPrevious) ? -1 : 1;
    // If we are in reverse mode, flip the direction of the encoder motion
    if (encoder->direction == REVERSE)
      encoderMotion = -encoderMotion;
  encoder->pinAPrevious = pinACurrent;
  encoder->pinBPrevious = pinBCurrent;
  return encoderMotion;
   Sends a message to Eos informing them of a wheel movement.
   Parameters:
    type - the type of wheel that's moving (i.e. pan or tilt)
    ticks - the direction and intensity of the movement
   Return Value: void
void sendOscMessage(const String &address, float value)
  OSCMessage msg(address.c_str());
  msg.add(value);
  msg.send(SLIPSerial);
void sendEosWheelMove(WHEEL_TYPE type, float ticks)
  String wheelMsg("/eos/wheel");
  if (digitalRead(SHIFT_BTN) == LOW)
    wheelMsg.concat("/fine");
  else
    wheelMsg.concat("/coarse");
  if (type == PAN)
    wheelMsg.concat("/pan");
  else if (type == TILT)
    wheelMsg.concat("/tilt");
  else
    // something has gone very wrong
    return;
  sendOscMessage(wheelMsg, ticks);
void sendCobaltWheelMove(WHEEL_TYPE type, float ticks)
  String wheelMsg("/cobalt/param");
  if (type == PAN)
    wheelMsg.concat("/pan/wheel");
    wheelMsg.concat("/tilt/wheel");
  else
    return;
  if (digitalRead(SHIFT_BTN) != LOW)
    ticks = ticks * 16;
void sendColorSourceWheelMove(WHEEL_TYPE type, float ticks)
  String wheelMsg("/cs/param");
  if (type == PAN)
  else
    return;
    ticks = ticks * 2;
void sendWheelMove(WHEEL_TYPE type, float ticks)
    default:
    case ConsoleEos:
      sendEosWheelMove(type, ticks);
      break;
    case ConsoleCobalt:
      sendCobaltWheelMove(type, ticks);
      break;
      sendColorSourceWheelMove(type, ticks);
      break;
   Sends a message to the console informing them of a key press.
   Parameters:
    down - whether a key has been pushed down (true) or released (false)
    key - the OSC key name that has moved
   Return Value: void
void sendKeyPress(bool down, const String &key)
  String keyAddress;
    default:
    case ConsoleEos:
      keyAddress = "/eos/key/" + key;
      break;
    case ConsoleCobalt:
      keyAddress = "/cobalt/key/" + key;
      break;
      keyAddress = "/cs/key/" + key;
      break;
  OSCMessage keyMsg(keyAddress.c_str());
  if (down)
    keyMsg.add(EDGE_DOWN);
  else
    keyMsg.add(EDGE_UP);
  keyMsg.send(SLIPSerial);
   Checks the status of all the relevant buttons (i.e. Next & Last)
   NOTE: This does not check the shift key. The shift key is used in tandem with
   the encoder to determine coarse/fine mode and thus does not report directly.
   Parameters: none
   Return Value: void
void checkButtons()
  // OSC configuration
  const int keyCount = 2;
  const int keyPins[2] = {NEXT_BTN, LAST_BTN};
  const String keyNames[4] = {
    "NEXT", "LAST",
    "soft6", "soft4"
  static int keyStates[2] = {HIGH, HIGH};
  // Eos and Cobalt buttons are the same
  // ColorSource is different
  int firstKey = (connectedToConsole == ConsoleColorSource) ? 2 : 0;
  // Loop over the buttons
  for (int keyNum = 0; keyNum < keyCount; ++keyNum)
    // Has the button state changed
    if (digitalRead(keyPins[keyNum]) != keyStates[keyNum])
      // Notify console of this key press
      if (keyStates[keyNum] == LOW)
        sendKeyPress(false, keyNames[firstKey + keyNum]);
        keyStates[keyNum] = HIGH;
      else
        sendKeyPress(true, keyNames[firstKey + keyNum]);
        keyStates[keyNum] = LOW;
   Here we setup our encoder, lcd, and various input devices. We also prepare
   to communicate OSC with Eos by setting up SLIPSerial. Once we are done with
   setup() we pass control over to loop() and never call setup() again.
   NOTE: This function is the entry function. This is where control over the
   Arduino is passed to us (the end user).
   Parameters: none
   Return Value: void
void setup()
  // This is a hack around an Arduino bug. It was taken from the OSC library
  //examples
  while (!SerialUSB);
#else
  while (!Serial);
#endif
  // This is necessary for reconnecting a device because it needs some time
  // for the serial port to open. The handshake message may have been sent
  // from the console before #lighthack was ready
  // If it's an Eos, request updates on some things
  initEncoder(&panWheel, A0, A1, PAN_DIR);
  initEncoder(&tiltWheel, A3, A4, TILT_DIR);
  lcd.begin(LCD_CHARS, LCD_LINES);
  lcd.clear();
  pinMode(NEXT_BTN, INPUT_PULLUP);
  pinMode(LAST_BTN, INPUT_PULLUP);
  pinMode(SHIFT_BTN, INPUT_PULLUP);
  displayStatus();
   Here we service, monitor, and otherwise control all our peripheral devices.
   First, we retrieve the status of our encoders and buttons and update Eos.
   Next, we check if there are any OSC messages for us.
   Finally, we update our display (if an update is necessary)
   NOTE: This function is our main loop and thus this function will be called
   repeatedly forever
   Parameters: none
   Return Value: void
void loop()
  static String curMsg;
  int size;
  // get the updated state of each encoder
  int32_t panMotion = updateEncoder(&panWheel);
  int32_t tiltMotion = updateEncoder(&tiltWheel);
  // Scale the result by a scaling factor
  panMotion *= PAN_SCALE;
  tiltMotion *= TILT_SCALE;
  // check for next/last updates
  checkButtons();
  // now update our wheels
  if (tiltMotion != 0)
    sendWheelMove(TILT, tiltMotion);
  if (panMotion != 0)
    sendWheelMove(PAN, panMotion);
  // Then we check to see if any OSC commands have come from Eos
  // and update the display accordingly.
  size = SLIPSerial.available();
  if (size > 0)
    // Fill the msg with all of the available bytes
    while (size--)
      curMsg += (char)(SLIPSerial.read());
  if (SLIPSerial.endofPacket())
    parseOSCMessage(curMsg);
    lastMessageRxTime = millis();
    // We only care about the ping if we haven't heard recently
    // Clear flag when we get any traffic
    curMsg = String();
  if (lastMessageRxTime > 0)
    unsigned long diff = millis() - lastMessageRxTime;
    //We first check if it's been too long and we need to time out
    if (diff > TIMEOUT_AFTER_IDLE_INTERVAL)
    //It could be the console is sitting idle. Send a ping once to
    // double check that it's still there, but only once after 2.5s have passed
    if (!timeoutPingSent && diff > PING_AFTER_IDLE_INTERVAL)
      OSCMessage ping("/eos/ping");
      ping.add(BOX_NAME_STRING "_hello"); // This way we know who is sending the ping
      ping.send(SLIPSerial);
      timeoutPingSent = true;
  if (updateDisplay)
    displayStatus();
By loddie
#96287 Hi Mogs,
Thank-you for providing this resource for serial<>UDP OSC. I realize this is a ESP forum, but I'm curios if your code would work with a Teensy ethernet adapter instead of WIFI (via ESP)? If not, can it be easily adapted to? I'm new to Arduino, but would like to use the same OSC communication pathway except with ethernet instead of WIFI for improved reliability.
Regards,
loddie
